maybe Worth a GB of both chips if any one is ablle to draw a dead quiet pcb for it ?
I2S inputt, current outputt for i/v conversion if avaliable ? All SMD with a Crystek -957 for Clock.
Yes, the chip is available. $4 each, but the minimum order is 25.
$4.- for a Sabre ES9038PRO chip? I'm guessing about the same price as for the last top-dog of the Sabre line, which was about $65.-
ismosys.com
Price for the 9038 not stated yet
Does the ESS reference voltage chip to work with this new ESS chip is avaliable as well ?
They even advice/encourage you to do so 🙂
The ESS reference voltage regulator is $4. The 9038 is $50, minimum purchase of 2 chips.
John
I am highly interested in this voltage regulator. It's probably the first regulator aiming for audio.
Why? This regulator so special?
Audio is a mixture of analogue and digital electronics, nothing special, there are many decent regulators that are good enough for audio as well as even more critical electronics....
The ESS regulator is designed to provide a simpler solution for using their DACs, it replaces numerous discrete components and separate LDOs around the DAC device, very useful if you are assembling many hundreds to thousands of boards cost wise.
Data Sheet.
http://www.esstech.com/files/3414/5193/1543/ES9311_product_brief_121715.pdf
Some guy is already playing with the new AK4497, but this 9038, seems be a still a news...
please see my DAC ES9038PRO:
http://www.diyaudio.com/forums/quanghao-audio-design/300246-dac-es9038-pro.html#post4907709
thanks
- Digital Line Level
- Any news about ES9038?
