Does anyone have a Sprint macros, that they're willing to share, for a small 9 pin tube socket like these from Amazon?
Amazon.com: SMAKN 5 PCS Ceramic Gold Plated 9pin B9A PCB Mount Tube Socket for 12AX7/ECC83/12AT7/6DJ8: Musical Instruments
Thanks...
Thanks...
Apparently no one here doesn't, so I'll create my own after measuring the pins of the ceramic socket.
Me too looking for the same. Ammel, can you share the macro if you have created it?
Thanks,
Bibin
Thanks,
Bibin
View attachment Vac tube.zipHere are some 9 pin makros that I drew. You might have to double check the hole sizes for the pads.
Edit: these were for some 9 pin sockets that I acquired years ago, so the diameter might not be the same as those available today.
View attachment 555090Here are some 9 pin makros that I drew. You might have to double check the hole sizes for the pads.
Thanks a lot Audiorasp.
Bibin
