Guillotine - son of Geriitts reductio ad minimum ribbon
Messed about with the terassed ribbon but given its thickness it could not take a lot of handling. So I mounted an other one which I corrugated with a new apparatus. These are 15um. Best measures yet I think. Level was quite high at say 98dB 0,5m. Higher order is really low witch is nice. Sounds nice but I think there is something special in thinner foils.
For this ribbon I also made it possible to adjust one end while playing 2Khz and at the same time using REWs RTA distorsion analysis for the final tuning of tension and flatness.
So I plan to build a mk2 version according to picture. I have now step-motors for my etching machine with should bring much higher control over the movements. Also this machine will contain 2 motors for leveling.
ai 0.3 percent distortion is till pretty high , if you ask me. but im not sure what mic you use. maybe it is the high spl you beat them with 🙂 i mean if the spl is a true value then ill take my words back for sure 🙂 BTW looks nicely flat !!! hope to see more when you are done with your DAC!
So after a long vacation finally the inspiration to assemble a pair of ribbons emerged. After some mechanical construction of a jig for fixing parts during glueing, I'm ready to mix the hardener with the base.
With this jig gluing was a joy. The second magnet just slid into the jig with no big effort and everything felt in total control - quite the opposite from the previous experience. The remaining assembly after one have 2 magnets will also be a breeze compared to the first versions. Easy peasy. I believe that the symmetry will be superior as this method forces everything to be aligned - hopefully with reduced distorsion as the result.
One down, 3 to go - really looking forward to hearing these in stereo.
Glad to see you're making progress. I wish you good luck with the assembly of the ribbons. It's definitely worth the effort if the ribbons turn out right, I'm still enjoying my ribbons every time I listen to my system.
regards,
Gerrit
Two makes a pair. Phjuu, they come out really well. Remains some removal of residual glue. I intend to use silicone to join the 4 parts in each driver in order to be able to separate them in the future if needed. As the N faces S it keeps together by itself but it surely needs glueing.
Now for a ribbon fastening and connection mechanism..
I now have 2 playing, each over a first order filter sat in at 5khz. There is a big peak but below and above it looks really good actually. There is I think something mechanical not ideal in my clamping system. Will look into this. promising of I can get rid of that peak and keep the rest 🙂 Mic distance was 30 cm. 2nd meas normalized and in %.
I was able to get rid of the resonance by playing with the ribbon tension, you could try different tensions and see what the peak does.
Do you use contact fluid with the ribbon when you clamp it? I use VanDenHul 'The Solution', it's expensive but worth every penny. Because it's a bit viscous it allows me to position and tension the ribbon before putting on the clamps.
regards,
Gerrit
