I'm about to make a crossover, and I saw the very elegant and not to mention cheap Visaton Stella Light crossover (made up of just two parts) for that particular FAST build. Is there any chance a build like that would work my speakers? I couldn't find too much theory or forum threads on these kind of filters, but I might be looking under the wrong terms.
My speakers as they stand are open baffle (Mark Audio CHR-70 third gen, metal, over Eminence Alpha 15a's). I know run both drivers full range like the peasant I am, and while they sound fun I have the idea I really need an XO 🙂
I'm sorry if it's a stupid Q, I only recently got in the hobby.
IMG_4861 by ctjr, on Flickr
Screen Shot 2016-05-18 at 19.03.35 by ctjr, on Flickr
It will certainly work better than no x/o.
Read :
http://www.quarter-wave.com/OBs/OB_Design_Part_1.pdf
http://www.quarter-wave.com/OBs/OB_Design_Part_2.pdf
rgds, sreten.
Read :
rgds, sreten.
Read :
rgds, sreten.
Hi Sreten, thanks for your reply, I was about to build the Martin King-variant (my speakers are obviously build of his papers), but if I could save some money by going for a simpler filter... I might just go ahead and build a King one.
Read carefully this:
Edit: Sreten was faster...
You won't save any money long run using the wrong filters.
rgds, sreten.
rgds, sreten.
Obviously; I do seem to have a hard time finding 30.0 mH coils though...
Hi, thy handle tells me, that thou may understand German a bit, Lohengrimas. There is a software called Boxsim, which can do most domestic loudspeaker stuff virtually. (Only thing i miss, is two different drivers in the same enclosure.) I sooner not equalize the open baffle bass loss completely passively but stop at 10 mH or so, just enuff to pull down level of the Eminence to the one of the Mark Alpair, and do the rest, what is still needed, on the small signal side. I would also be on the Less Is More side and try to archieve flat phase response(, which Boxsim does not tell thee, it only tells single driver phase, but thou can deduce über-alles phase easily). Grasso
yes, thanks, I'll try Boxsim, and thanks for the guidance!
Hi, where do 30mH coils come into it ? rgds, sreten.
- Series filter (Visaton stella light) for open baffle?
