Older VTA standard issues
I've experienced difficulties with some old phono cartridges, they do have 90 degrees VTA. Mono cartridges include: EMT OFC25, OFD25. Those were dedicated for microgroove records. The same problem with Stanton 380, it is a stereo cartridge, and perpendicular VTA seems to be improper for stereo records? Only after the whole cartridge angle was corrected for obtaining 15 degrees VTA, it's sound opened. Same story with ancient Grado GL stereo MC cart (see pictures). I'll be grateful for info about VTA standards history, especially when they switched from 90 degrees...
Administrator
Joined 2004
I'm by no means an expert, and am still trying to figure things out, but I suspect it has a lot to do with stylus geometry. I know that my Ortofon Windfeld with Replicant 100 stylus (line contact) is extremely sensitive to VTA and that to sound its best the stylus has to be very close to 90 degrees to the groove surface, deviate more than a few degrees and things get nasty fast. I have two other cartridges with line contact styli, while they are also quite sensitive to VTA it is not to nearly the same degree as the Windfeld. I also have two cartridges with an elliptical stylus and they're very forgiving, but also come nowhere close to the level of performance of the two best line contact cartridges in my system.
Joined 2002
walterwalter
As far as I know, VTA was never 90 d. It varied a lot but it was nowhere close to 90 d.
At around 1958 it was standardised at 15d, by 1975 it had gone to 20d.
See here for a good VTA history summary (1960 and on).
VTA
I like the wedge you’ve made.
Kevin
Get yourself a spherical tip. It makes precise VTA adjustment unnecessary :D
With a DenonDL103, I can not hear any change, with a Shure M97xE VTA change becomes a bit noticeable (but I am half deaf).
Exposing the VTA myth? [English]
George
walterwalter
I hesitate to bring this up after youv've slaved over that wedge, but...
If you've got $400+ usd or so burning a hole in your pocket, Dual cs5000 arms have an adjustment for setting VTA in the headshell. Check the pix, and you will see a dial mounted in the shell, facing up. Dual first used this on the Perpetuum Ebner changers(30 series) they produced after buying PE in 1972 IIRC. PE had had this feature for some time. The reason they gave for it was to deal with the change in height of a stack of records. A PE 2040(last produced before sale to Dual) is IMHO better than Dual 1229, its' contemporary equivalent. They go for less than the Dual cs5000 tables.
Administrator
Joined 2004
walterwalter
VTA
Kevin
George
I hate spherical styli.. lol I owned a Zu Denon DL-103 which was an excellent cartridge at its price point, but in no sense compares to a properly set up Windfeld. (Mine is not necessarily representative at any given moment in time. :D )
Joined 2002
