Hi friends,
I have picked up a WADIA WT-3200 CD Transport that I currently restore: particularly I change all the caps and belts...
But my problem relates to the remote control : I have got this transport without the remote control, and the generic manufacturers including "All in One" do not know this remote control model and cannot provide a compatible one.
Do you have any idea of what I could do to get a remote, or tweak an existing one into a remote compatible with this transport ?
Philips RC codes are very commonly used among non mainstream products. Have you tried whizzing through Philips CD codes on a universal remote ?
Yes,
Since I posted my first message, I have got the confirmation that the WT-3200 uses the same base than the PHILIPS 960 CD Player.
So the solution is to find a remote compatible with the PHILIPS 960, but this is an old model so it is not referenced in the databases of the website sellling the replacement remotes (at least, I have not found it to date).
Is ti possible to be sure that any PHILIPS remote would be OK, or do I have to reduce the scope to some remotes only ???
I think you should try and narrow it down and prove that a Philips type works OK. Universal all in one remotes (the £5 supermarket type) should prove that.
I have a Micromega Stage 2 and there are several Philips codes that work it OK. A friend has a Sugden CD player and my original Micromega remote works the Sugden and vice versa. I also tried Lidl and Aldi remotes in the past, and they had the basic functions covered.
You are right : a Philips CD-960 remote should work because the base of this transport is a Philips 960 or a Marantz CD-95 (I have read this in a few other places). I have ordered one and will test it in the coming weeks...
I have another issue: the LCD display is poor : any idea of the place where I could buy a new one or a replacement ?
Good luck with the remote.
No idea on the display I'm afraid. Are you sure its an LCD ? Just looking at some web images and it looks more like an orange VFD (vacuum fluorescent display). These are glass, they are fragile, and they have a tiny 'pip' where the glass envelope is sealed.
What is the problem with the display ?
If it is a VFD then common problems are capacitor trouble in the supplies that generate the negative rail required. Usually its a couple of electrolytics that have dried out. Other problems can simply be that it needs a good clean of the display and the window on the inside. They seem to attract atmospheric dirt.
Hi Mooly,
Regarding the remote control, I have found a Philips CD-960 remote on internet, that I should receive in a few days/weeks: I have been told that it is compatible. So I wait for it and will go back to you if I have to search for another solution.
Regarding the display, it could be a VFD. I have totally recaped the Power Supply (as well as the rest excluding the display board), so the display is OK now.
But I am nevertheless looking for a replacement display because I plan to give it to my grandson as an heritage !! 😀 More seriously, I use to have a replacement display for all my devices than I plan to keep for many years...
Any idea to where I could find such a display ?
I wouldn't like to guess where you might source a display... Wadia of course, but other than that, I don't know.
The best you could hope for is that it matches a known common product such as one from Philips, but it looks a bit unique from the pictures I've seen. That said, tooling up for a one off part of limited sales is very very costly so it may be one from a Philips/Marantz player of that era. You would have to do your research beginning by looking for images of all the possible players.
Well, it is a Marantz CD-94 / 94 MkII / 95 display. Philips CD-960 has different one.Any idea to where I could find such a display ?
Btw, your whole machine is a Marantz, except faceplate and ST output 😉
And the price 😀
Thanks for your advices guys...
Yes I know !
Error : I have got it for quite nothing because the belts were died and the previous owner did not want to keep it...
So, I had to pay 10€ for the belts and no more than 30€ euros for the capacitors because I have entirely recaped it from A to Z...
The cheapest Transport that I have ever seen
Yes I know !
And the price
- Digital Source
- WADIA WT-3200 Drive Remote control
