♫♪ My little cheap Circlophone© ♫♪
this acceptable ?
Inverted J-FET Circlophone PCB's
Because not all the PCB-orderlist subscribers claimed their boards, I have a few spare boards available for those who are still interested.
First come, first served until the stock is exhausted.
@Userguide: thanks for your confirmation!
Have fun building!
Does anyone know if the Teddy PowerReg would be a good idea for powering the Circlophone?
I was going to use them to power a chip amp but got persuaded to build the Circlophone instead.
Like most "normal" amplifiers, the Circlophone does not require a regulated supply..
In the best case scenario, if the regulator is truly excellent, it will change nothing.
If the regulator has shortcomings, like a funny output impedance under certain transient conditions, it may cause a degradation.
Thus, adding a regulator adds complexity, cost, increases the risk of problems and reduces the OP power (the regulator eats up some supply voltage) without bringing anything positive.
A good standard supply with a large reservoir capacitor directly on the Circlophone's supplies is all that is required.
You can play with CLC or CRC too, but the last C has to be large, >2200µF, preferably 4700µF
