Apparently it is good and not all marketing hype.
Please enlighten me on this technique to throw away information and make the result better than the uncompressed bit perfect data.
Speaking of loss of information someone other than TCM is showing "Barbarella" right now.
Bcarso-curious what you find out. I'm interested in playing with designs similar to euvl's sen I/V and have a general antipathy to matching.
Massive LA article in the works on JFET's, modeling, matching, etc.
Looking forward to it.
Yes, glad to hear. I have to catch up on the last couple of issues as well.Looking forward to it.
My one experiment paralleling relatively loose-matched 862s was fairly successful. I made a stack of them and soldered bus wire along the lineup of leads, in hopes of minimizing inductance and to act as a heat conductor/dissipator. A simple amplifier constructed thus was free from VHF oscillations without ferrites etc. The noise was inconveniently low to reliably measure.
Speaking of loss of information someone other than TCM is showing "Barbarella" right now.![]()
Next time you wave,
please use all your fingers.
I would not assume that will be what is happening. It would not get such a review and comment R.H. gave it if that was going on. I certainly wouldnt.
The IEEE paper I put up points to the future...
There is only the opening scene that shows anything....... pretty breasts..... you will be wasting your time waiting to see more... there isnt any more to see..
-RNM
You can store uncompressed formats directly, bit perfect, especially you why bother with less?
Just joking on "Barbarella" (you are wrong BTW) I have seen it many times including in the 60's. In fact I screened it at MIT on first release, got the nerds bouncing.
Hey, Scott, while I have you here... microphone noise floor measurements. If I recall right, you buried a mike in sand in a barrel to measure that? Is that right? And if so, what did you wrap it with?
A 1 gal. food storage bag.
I must have seen the 'edited' version more recently. what did i miss?
I am not interested in any compressed formats.
THx-RNMarsh
THx-RNMarsh
So you have uncompressed hi-res audio what "enhancement" is necessary? Other than adding DRM what is MQA all about other than another lower than max necessary bit rate system? You can slice it anyway you want but Shannon wins, if it's less than the entropy it's lossy. Possibly you were fooled at first like I was there is no lossless compression that beats the Shannon limit. FLAC et al get close but are not perfect OTOH the room for improvement is limited.
If what they have done is losslessly encoded in a more compact way.... smaller file size can be streamed with master quality. But streaming isnt a big concern to me but would be nice to have as replacement for FM. Otherwise, I am OK with large files size of HD downloads for storage and playback.
Meridian Audio?s MQA technology is the best product at CES so far | TechHive
If the two are equivalent in performance, then I do understand the reason why it is liked so much..... close to the master's sound is very dramatic improvement over typical CD.
I am thinking there is more to it......
THx-RNMarsh
THx-RNMarsh
also...
NEVER laugh at your wife's choices.
You are one of them
ha ha - I like that.
Archimago's Musings: MEASUREMENTS / IMPRESSIONS: Meridian Explorer2 Analogue Output - 24/192 PCM vs. Decoded MQA. does make you wonder what is going on.
BTW do you trust an article by someone who can't even do basic research? In that techhive article he claims Meridian invented SACD. I remember Bob being very vocal about 'never twice same bits' and pushing MLP as a better solution.
If you put the whole contraption it in the refrigerator overnight, I am sure the noise would be even lower the next day.
Hey Ed, you could try putting your pico-Volt preamp into a flask of Helium
(I dunno if the batteries will work down there though . . . )
Looks like certain contributors here are challenging the physics boundaries only to get free lessons, without being eventually required to admit their own ignorance. Much better than facing the risk of asking direct questions, that could shatter their guru status.
- Member Areas
- The Lounge
