arcam fmj a32 dim display noise
This is my 2 project I worked about a year
arcam fmj a32
and
denon dvd 2900
I still have a little problem amplifier
When the display to dim mode
There is a little noise from the speakers. High frequency
When the display is turned off or in full light
Quiet.
I tested the amplifier ground.
All the star ground
All chassis connections.
5V voltage display clean.
From what I know from other products SMD capacitors
Can introduce oscillations to the display circuit.
Again little problem that everyone arcam amplifiers have
If someone has a tip how to solve it, I'd love to hear
I shot this video of the noise
Link to the video on YouTube
https://www.youtube.com/watch?v=96Q8uRQ1yxw&nohtml5=False
Did the fault appear after you "worked" on this project?
The problem was always before I started working on the project.
This amp burned two years ago
I started
Repair Project
Then I did it so is the project comprehensively improve it
It sounds amazing
Even 70 percent of power is at room temperature.
Before the project he was heats a lot.
Then burned in flames.
Darlington transistors 15 SAP burned
and a lot smd resistor and diode burn .
I switched to SAP 16
This amp mostly SMD components
Many protection circuits
No one at the time could not believe that I could fix it
Because I fixed it with just a multimeter
And capacitor tester
Paper and pencil
And 20 pages of circuit analysis
Until I solved all its problems.
All amplifiers ARCAM
Have this problem
The noise is only a dim display on.
I was able to significantly bring down the noise level
By addressing circuit 5 volts.
But the noise still exists, though weaker
I guess it has to do SMD capacitors
In the display circuit
This thread i opened two years ago wan started the repair project. And improvement
http://www.diyaudio.com/forums/solid-state/248632-my-diy-arcam-fmj-32-amp-mod.html
I'll check the
op amp ad8532
on the display bored
I would replace the X7R SMD capacitors.
The decoupling smd caps of the ad8532
I'll see if it will improve the situation
I was able to resolve the shrill noise
Almost completely
By replacing the op amp from LT072 to OPA1662
Z111
Z113
At the input of the pre-amplifier
Shrill intensity Reduced About 50 percent .
The most important problem of Small clicks sounded from the speakers when I up and down the volume completely disappeared 🙂
I later Also replace the op amps
Z112
Z114
to OPA1662
I only had two units at the moment
I will order another couple and see
If the problem is completely solved.
(Usually I really like the sound tone of the op amps JFET-based But they are much more noisy )
Input Bias Current of the OPA1662 bigger 600nA
Compared to the LT072.... 65na
But because of the resistor values in this part circuit
low
So I was not to worried About offset error.
