Amp with transformer
Project development...
showfull.php
showfull.php
Thank you.
An other (not so nice) circlotron, meaning ?
Speaker between cathodes or anodes or both, same thing.
Mona
If a speaker with a single coil, it is connected between the anode (№1 scheme).
If only a bifilar coil, it is possible to connect a variety of ways:
1. Between the anode by connecting the coil speaker series. End of the first to the top of the second.
2. Either turn, both in the second scheme directly between the anodes and cathodes.
3. You can enable two different dynamics. One between the anodes and the other between the cathodes. This option is needed for kontaperturnoy acoustics.
Thank you.
Thank you.
Or,
4. like this
5. or that 😀
Mona
