bourns has a data sheet for one but finding it in stock is a whole different ball game... http://www.bourns.com/data/global/pdfs/PTD90.pdf
you might be able to find a 3 or 4 gang and take it apart and build a 5gang using parts from 2 smaller multi gang part numbers but that might be more hassle than its worth. Thats the route I've taken when I've replaced one that I couldn't find in stock...
You can always cut the unused pins.
2 x 9mm Alps A50K 50K Audio Taper Potentiometer 15mm Knurled Shaft 6 Gang | eBay
The shown pot has some of its pins bent.
Would you trust these products are really ALPS ?
The seller has good feedback,
- General Interest
- Car Audio
- 50k 5 gang potentiometer
