Not what you are looking for but I have SEOS-24, 1.4" throat horns for sale in the US and matching Faital HF144 drivers to go with them. The 1.4" exit drivers hit the sweet spot between low-end extension and HF performance. Ignore if not interested.
Hello, I already have 1.4 faitals. What range do the HF144 cover in the SEOS 24? Why are you selling? How much do you want for them without the drivers?
In the SEOS-24, the HF144 can be crossed as low as 500 Hz. You'd need at least 24 db/oct slope at 500 Hz though. Spec sheet here:
http://www.faitalpro.com/products/files/HF144/8/HF144_datasheet_8.pdf
Member Face was able to achieve impressive results with a cardoid woofer and SEOS-24 crossed at 450 Hz.
http://www.diyaudio.com/forums/mult...z-using-really-large-drivers.html#post4481539
I personally didn't like the imposing nature of the beast I had created with the horns and VOTT cabs. Plus I am trying to reduce the number of goodies I have. Sale ad:
http://www.diyaudio.com/forums/swap-meet/284196-drivers-horns-speakers-electronics.html
Link to SEOS-24 pictures:
http://www.diyaudio.com/forums/swap...horns-speakers-electronics-2.html#post4582406
There is a small imperfection on one of the horns as you can see in the pictures. Can be easily painted on to make it invisible. I just didn't want to mess with it.
Normally, these sell for $207 a piece new. Shipping will be about $50 in the US (what I paid). Yours for $400 shipped.
Thanks, what is the usable bandwith without EQ with the horns? I found with the little SEOS 12 some drivers work well with little to no contour and some are really out to lunch. Do you have a response measurement for the combo I can take a peek at? I am looking to use the horns with a large format driver 500-600 up to around 6K and no EQ thinking the 30 may be the ticket with a 2" driver
These are constant directivity horns, so expect some HF droop. I'll try to see if I have the measured response. I should have it somewhere. I think these will be comfortable from 500 Hz all the way to 20 kHz assuming you have a steep filter at 500 Hz (24 db/oct).
It depends on the CD. With a BMS 4594, it'll work as low as 375hz in low power applications, 450hz will handle a moderate amount of power. Flat response can be attained via passive filtering.Thanks, what is the usable bandwith without EQ with the horns?
