Hypex NCore NC500 build
So, how is it working? Fighting the people of "faith and superstition" by putting words in their mouth they are not even saying, but are just product of your own imagination and/or other templars of science.
I think it is you who are stereotyping with the "templars of science" here. Your comments would be appropriate if the audiophile foo I was referring to was actually just a product of my own imagination, but unfortunately I have came across all that stuff for real, all to often, on numerous "audiophile" boards - many of which actually have explicit rules against questioning (or even clarifying) any claims, no matter how absurd.
Like in this claim that the "audiophiles" are saying that "XLRs are only for the pro stuff", even there is no consensus of such claims and nobody knows a person that has actually said such things.
You might not know one. I definitely do.
And nothing supports such claims.
If you say so.
To me, the main problem of "pure science based objective truth"-hifi is that it worked if the people making the music would be pure science based individuals.
Let's not commit the standard silly mistake of confusing making music with reproducing recorded sound. Two entirely different things.
If i for instance use cables and opamps and what-not to deviate just a bit from the objective perfection to hide things/truths from me that i find just too annoying, do i turn from good guy to a person of "faith and superstition"?
No, but if you make a claim that a cable alters the sound, and make that claim purely based on your own subjective, uncontrolled observations without any other evidence, then you have stepped outside the fields of science and engineering and into belief, superstition and faith (or perhaps marketing).
I certainly hope so. It is just circuit analysis.
The rest is, well, boring and tiresome; and, I suspect, it is of little use to Boggit. 540+ posts and little actual content. Again. Best to simply walk away from the repetitively boring off-topic red herrings.
Well, talk to that guy then instead of talking about him behind his back. To me you are still part of the "templars of science". I think the tribe name suits you well. That or "bullies of science". Take your pick.
For you it is a silly mistake, for me it is pretty important.
My signal path continues from speaker to my through the room, to my ear, and even to my brain. So i allow myself to have a personal opinion or things i have actually tried. The main function of my hifi set is to make me a happier or more relaxed person. I have noticed that that cannot be achieved in my case, purely based on science we currently know. I don't care so much anymore about the "the real" as objective truth, but how things affect my perception (the subjective side), being it red color, or different R,L or C values on the cable.
Interesting topic going on here. Seems like we have hit a dead end for the hard core objectivists. I am reaching out for solutions to my questions but can't seem to get any solid ones:
DACS Have they gone about as far as they can go? | Audio Science Review Forum
I wonder how this will eventually be sorted out as far as I understand we have one person saying 47k resistors are causing noise and another saying that they are not so what is the answer.
What do you think the answer is?
The physics of what I posted is very straightforward. However, a couple of points to remember... Boggit has not disclosed his circuit (or BoM). His circuit may be different from the one I posted/analysed. I have not had access to the physical one. I believe the Sparkos folk analysed the Hypex circuit. Again, perhaps this is different. What I did is look at the "recommended" buffer design and add in the components I would expect to see in such a circuit dealing with EMF rejection, DC blocking etc - the bit in the box on the left (of course, the physical circuit ought also to have supply bypassing at the op amps etc.) - and also add on, following Application Hint guidance, model components to analyse required op amp output currents. Maybe, for example, the actual circuit omits such things as DC blocking capacitors which would not, in my view, be a good idea.
(My analysis so far has been constrained to resistor noise generation and op amp output current demands. I've not examined other aspects such as stability.)
You are at an advantage - you have the physical circuit. Look at it and tell us what you think.
Were I to design an input buffer for the NC500 I'd be much more focused on how to lower the size of the resistors in the feedback network. I've already pointed to references as to how that might be achieved.
Once again, if you identify any errors in my analysis or thinking I welcome the correction. We are all hear to learn. What's not useful is sitting there saying "tell me the answer" or erroneous technical discussion (not even to mention the rest of the subjective babble).
PS: if you want another reference reading as to the discussion of noise relating to such "47k resistors" (not a good label but useful shorthand for the topic at hand) purchase Samuel Groner's article for Linear Audio relating to his low noise instrument amplifier. It will cost you about £3 and is well worth reading. The first part of section 4 relates to this topic but the entire article is well worth reading.
Boggit has already said what circuit he's going to be using. The schematic has been posted on this thread already. Did you not read anything that's been said on this thread? I'm not sure why you are trying to imply you had a part of any contributions what so ever with the development of any buffer boards just because you read the NC500 data sheet.
"Going to be using"
Future tense. My reference was to what he is using. And the full schematic, not one with items omitted "for clarity".
And I am not implying anything at all. Your imagination runs wild...
Well you keep babbling on about buffer designs when a solution as well as measurements have been provided on this thread already. Colin has confirmed that he has tried this circuit and it works great. He's making a new board based on it. End of story.
I've also built an input board based on this circuit months ago. So unless Colin can come up with a better circuit, I think this issue is settled.
