hi these parameters are of LG 7.5 inch subwoofer model number LGZ40 ???
Yes
This is the enclosure for LG 7.5inch Woofer
As mentioned earlier in this thread...No, it does not!
Go for it...Disregard my previous post.
these parameters are for LGZ40 7.5 INCH SUB???
these parameters are for LGZ40 7.5 INCH SUB???7-3/8 woofer by LG. 4 ohms/180 watts. Mechanical Parameters: Fs=50.0 hertz, Qms=4.600, Vas=0.391 cu.ft, Cms=0.045 in/lb, Mms=1.396 oz, Rms=6.058lbs/sec, Xmax=0.138 in, Sd=27.3 sq. in. Electrical Parameters: Qes=0.984, Re=3.5 ohms, Le=0.6mH, Z=4.0 ohms, BL=6.6 N/A, Pe=1800 watts. Single Driver Vented Box Parameters: Vb=1.522 cu.ft, Fb=26.8 hertz, F3=23.6 hertz, Fill=normal, Ports=1 (round), Dv=1.60 in, Lv=3.37 in. These are heavy duty, quality speakers.
HOW YOU OBATAIN
Thanks guangui , how you obtain these parameters?
Greets!
Not enough dimensions to tell how it might perform, though judging by the posted specs it doesn't look like something I'd want, at least without a lot of stuffing to damp it.
GM
Simmed this one and it does need a lot of damping............
GM
So I don't know which kind of enclosure suitable for this drive, which is the theoretically suitable enclosure box for this driver.
A 32.9 L [net] BR with a 5.07 cm^2 x ~1.9 cm [baffle thickness] long vent and damped to 'taste' seems a decent small cab compromise.
If ~2x larger TLs are an option, then up to 5-6 dB higher SPL down to around 30 Hz is a viable option.
GM
- Full Range
- Enclosure For My Speaker
