Hypex NCore NC500 build
Yes agree we need Boggit to design the best possible buffer.
Although I suspect it is not as easy as we think.
Why don't you design your own? This is DIYaudio.com...
Only problem is which one is best as I have said before I find the Burson best for me but others have found they prefer Sparkos
You could design an input buffer around your preferred op amp...
I think Linear Audio archives are only available on paper, but some of the more interesting stuff was also published in EDN (that used to be Electronics Design News).
The only Bruno article Linear Audio has online is the famous "The F-word", mandatory reading for anyone into nCores.
Anyway, if you look at who writes for Linear Audio you might want to buy all the back issues anyway 🙂
No. You can buy individual articles which are sent by PDF.
http://linearaudio.net/articles
Two "must buy" articles, in my opinion, are Samuel Groner's Low Noise Pre-Amplifier (just for the noise analysis) and R Marsh's Headphone Amp. But I am sure there are others that are well worth it depending on your interests. But the two back-issue articles Bruno wrote for LA are available on his website. Certainly the G word article is:
http://www.hypex.nl/docs/papers/The G Word.pdf
The typology for the balanced volume controller will be familiar to anyone who has read the application hints section of the NC500 data sheet and noted the recommended buffer design.
Worth a read also:
http://www.hypex.nl/docs/appnotes/pin1_appnote.pdf
Thanks SGK
Been reading the Hypex link and find this quite amusing (RCA cables) commentary by Bruno
"There is a reason for the sprawling cottage industry that audiophile cables have spawned. Unbalanced connections affect the sound quite strongly for reasons that by now should be quite obvious. The whole idea of having one of the actual signal wires also do the dirty work of shunting equalizing currents away is barmy. To then try and solve the problem by eliminating those currents is bone-headed. To try and molly- coddle the sonic defects this causes by making outlandish cables is madness. The RCA connector and all it stands for should be banned by law"!
Yes it's a shame that different people have different tastes in sound. Too bad we weren't all androids with hearing on par with the finest measurement mic's.
Which is why I believe in making gear as neutral as possible, and then giving people tools to shape the sound to whatever they want. I guess I am in a minority wanting to hear a sound that is as close as possible to what the studio/mastering engineer heard in the monitoring speakers...
And I totally agree with Bruno on that one. But ask a real audiophile, and he (invariably a he) will tell you that balanced connections and XLR connectors belong in the pro audio world, and the people in the pro audio world don't know anything about *real* hi-fi... 🙂
Quite the opposite actually. We demand balanced interconnects even when they're unlikely to be better standalone than unbalanced.
The more powerful point Bruno is making is not so much balanced vs unbalanced interconnects, but rather completely removing the signal ground reference from typologies. Having spent a good deal of time lately designing a balanced input board to interface with a very high quality amp which has an inherently single-ended IPS, I have a good deal of sympathy for his view.
My Theta DAC only has balanced connections.
Heh, try to suggest balanced connections and XLRs on some "serious" audiophool forum...
Yes, but to remove the ground reference, you need differential/balanced connections.
Indeed but you can have balanced connections in single-ended typologies that use the ground reference. Cart. Horse.
Sure. To be clear, I am definitely advocating differential, fully balanced, and "groundless" topologies. But a lot of audiophiles still seem to believe in not only unbalanced connections, but even worse, star grounds.
Good luck getting everyone to do that. People will always judge stand alone amps by how they sound in conjunction with everything else in their system. If it's a complete integrated system from start to finish all in 1 package it's a different story.
...and they may also judge your All-in-One by the Loudspeakers they use it with (and room responses)
We will never be happy ;-)
Well then you better not have anything more transparent / ideal than "hen", as we say in sweden, hen being a combo of he and she (han / hon) ... 🙂
I guess that is why I mostly listen at my computer using Genelec monitors 🙂
The real issue is of course that studio setups (and sound engineer preferences) vary, so guess I am still best off with a "neutral" approach.
That's why there was a smiley at the end of my comment. 🙂
You have hit the basic problem with subjective evaluations - they are subject to individual taste. That is why I rely as much as possible on objective tests and strive for neutral transparency in my gear - any subjectively pleasant coloring is best added separately.
I'm with Julf on this one, as is Bruno in the design philosophy.
As it has already been pointed out, the design concept of the NC500 is to be so neutrally transparent. As mentioned in the design notes and elaborated at length in this thread 🙂, one can then tweak any colouring as part of the input buffering. However, even then, you still have no real control over the external interfacing hardware and what sound envelope they might bring.
Looking at the whole chain:
[Source] => [DAC] => [Preamp] => [[Buffer]+[NC500]] => [Speaker]
There are many areas where colouring can be applied. And that's before you even start talking about personal preferences. Oh and I didn't mention interconnects or speaker cabling either. Let's leave that out for now!
I for one prefer a rather bright, revealing sound. And for that, I love the transparency of the NC500 and the very simplistic, basic LM4562 buffer adapter Hypex make. I've replicated it myself in my testing and found it interesting comparing to the NC400 where the buffering is already built into the module (I can't remember off the top of my head what the circuit for the NC400 is). You could also say that simple ~= better in that the lower number of components you add, particularly active ones. But my testing for the moment is doubly subjective: (1) I'm using my ears and (2) my personal preferences can distort perceived quality of sound. One day I'll invest in a proper analyser which won't throw in its personal opinion on the measurements!
Again, Bruno / Hypex point this out in the datasheet when looking at truly differential opamps like the LME49724 interfaced with a DAC.
There are no inherent performance benefits attached to symmetry. In fact, in order not to lose performance the drive circuit needs some forethought in order to keep the number of amplifying stages minimal (i.e. one).
Less is more. 🙂
