Hey all.
I love these little things. So easy to make and mod. I'm running this one at 12V/2A with 3156 bulb. By itself, it's very quiet. With a preamp, it will wake the neighbors. Check out the vid below.
Zen Bulb Amplifier
Zen Bulb Amplifier
I like it. Great project for a budding amplifier builder. I am going to show it my Grand-kids and see if I can generate some interest in electronics.
Pretty cool. So no need for a heat sink? Just using the amp case?
The case is plastic. There is a huge heat sink on the mosfet. If you used a metal case, you can get away with using it to disperse heat, or at least some of it. I made a few in metal boxes and what I did was use a smaller heat sink attached to the side.
That's fantastic! It's easy enough for sure. They can even do a 6V version to start.
