you'll question the value of opamps as preamps.
I don't question their value at all. They can sound really good if you know which ones to use and implement them properly.
I've built and listened to a couple of the JC-2 clones. They sound okay for the money...nothing spectacular.
While I don't like bright-sounding amplifiers, I find the 6SN7 to sound a little too dark.
I want to clarify ; I completed this pre with BC550C and BC560C ( unknown brand ) as required by progetto.Esso does not provide an output capacitor, try this can be dangerous for the presence of DC , but it can be unvantaggio for sound. The power amplifier , however , provides a coupling capacitor of 1uF input . As I said at the top , the sound of this preamp is really very interesting , but I "only" a limit , I think my only , at low frequencies ..... them feel not very deep . Can be due to use of BJT unmarked ...?
Bearing in mind this is a dc-coupled line amp with 4.3 gain, the only reason of being "not very deep" at low frequencies I can imagine is impedance matching with your power amplifier. Try to add a follower at the output of the preamp in order to achieve a low output impedance.
... Thanks for your advice , but what do you mean by "add a follower" ?...
I have to lower the output impedance of the preamp ?
I have to add such a buffer ... ?
Exactly - you need to lower the output impedance.
Here is a top quality buffer for your purpose.
Valery
I see the sch shows AP after bc560, but BP after bc550
Is this the gain grade i.e. A, or B?
Ah - yes, please don't pay attention. My simulator model's markings.
One should use the same grade. B or C are preferred.
Ok,You have developed the PCB ?Exactly - you need to lower the output impedance.
Valery
No, I have just developed the schematic for you 🙂
You can bread-board it easily, I believe.
But, if i Connect to preamp a Buffer X10D as impedance adapter?
To be honest, I'm not a big fan of the tube buffers. X10D's output is taken from the anode, so... I don't consider it as a good thing for the purpose. Yes, it's called "buffer", but it does not really give you the low impedance output.
Thanks...
Valery
... I can replace mje350 with equivalent?
I hope someone will drow a pcb for this preamplifier
Let's wait....
Valery
Hi.., You have tested it? Did you hear how it sounds? I can use, according to you, only as a preamp ....
I used this kind of topology many times in my designs.
This kind of buffer, if built correctly, does not sound. You can treat it as a piece of wire with high input impedance and low output impedance - 0db voltage gain, virtually zero distortion.
ok, thank you, very clear ....
Valery
Hi! ... This schematic is for one channel, right? ...... Do you think I can use the same PSU preamp, for the supply of voltage buffer ...?
- Diy preamp for Amplifier IRFP240/IRFP9240
