Replacing electrolytic caps in crossovers - what voltage rating to use?
Hi guys,
I am replacing the 17-year old electrolytic capacitors in the crossovers of my Infinity Kappa 7 speakers.
These capacitors are rated at 100V.
Will it be ok if I were to use 63V or 50V capacitors as their replacement?
I am thinking of using Elna Silmics as replacements. 100uF Solens are too big and too expensive for me right now.
Appreciate your help. Thanks.
Sorry to resurrect a thread from the mummies, but Google led me here... I have a pair of Infinity Q3 with dual voice coil Watkins. I am therefore thinking of replacing four 600uF caps that are connected in series with chokes and the woofer coils. I like to play loud, and I now have the Hypex nc500 amp from diyaudio user Boggit. It can peak at about half a kilowatt. These speakers can dip to 2 Ohms, as the voice coils are paralleled. I can see no voltage rating on the old caps. They are original (circa 1978).... What do I replace them with?
At 600uF times four, yes anything but electrolytics will be excessively expensive, and I anyway gather that the quality of woofer caps isn't all that critical. Would you agree?
The bypass is interesting. Do you mean to parallel the bipolar electrolytic cap with a film cap of something like 10 or 22 uF? And why is that good?
No, the real question that matters is how much voltage can you send
to speakers without destroying these? :spin:
You think bypassing with smaller caps makes sense? Can you bypass
a VW Beetle with a Porsche sticker and say that it's now a sports car?
Amazing how people don't do simple homework.
Infinity Quantum Serie
I'd lose the 600uF in the Infinity QLS 3 altogether. They hardly do anything. Kappa 7 schematic follows.
Quite alarming 2 ohm impedance from the dual-voicecoil woofer. You wonder why separate filters were used on each voice-coil, which must sum to something simpler. Who designs this stuff? LOL
half a kilowatt into 4ohms is roughly 63Vpk. Allowing for a worst case output voltage peak of 70Vpk then I'd suggest the absolute lowest voltage bi-polar or non polar capacitor you can use is 80V. But I suspect you can more easily source 100V bi-polars, if you need them at all !
It's gotta be 100V Non-polars in a speaker that goes so loud.
I usually go by the power rails on the amp. A 20W pc amp has a +/- 30V power supply. Assuming you don't have high-Q resonant LCR circuits which multiply voltage.
A more powerful amp can output much higher voltages.
