Im considering using the Faital Pro 15PR400 in a high effeciency 2 or 3way system. Need to use the Faital up to around 1kHZ (plus or minus a couple hundred) depending on the horn/waveguide I end up with.
Would like to get some suggestions on interesting designs.
Multi-subs will be used but low end extension is a definte plus.
Large or tall. Huge or small . I ain't scared...
Anyone ?
Daniel
Anyone ?
Daniel
I've been looking at the same driver, similar situation really. I know you said "Multi-subs will be used but low end extension is a definte plus." , but it seems like with multiple subs then a small sealed enclosure would be the way to go. In a 2 cubic foot enclosure the excursion is well enough controlled to not need any kind of high pass.
-3db @ 75Hz
-6db @ 58Hz
should be fairly easy to cross a sub over to...
Having said that I'm interested in seeing what other people suggest. The Faital Pro 15PR400, looks to be a really nice driver. Low le, low mms, reasonably clean rolloff if the published graphs can be trusted.
-3db @ 75Hz
-6db @ 58Hz
I'd personally do without the subs and just go with dual 15s, at least I would listen to those 15s first before investing in subs.
Why would you want to use a driver this large up to 1KHz? You will need directivity controlled midrange, probably a horn, for a proper directivity match between the drivers if crossing over this high..
Edit: I should learn how to read first, because I now see on looking at your original post that this is exactly the plan. I like the Faital 3FE20 very much as a small mid range, so I have good experiences with their drivers. For an enclosure, high efficiency and small size don't go together. My guestimate is that a 200 L bass reflex will obviate any need for sub woofers.
Go for it.
Build an Onken style cabinet
gosh, an old thread from february
and no response until now
not surpiced if he is long gone
anyway, looks like it will do Onken ports ok ... but will be a small onken
Does anybody have the plans for the faital onken/BR box? 40hz will do me
Thanx
http://www.humblehomemadehifi.com/library/Humble Homemade Hifi_CAD_Calpamos.pdf
- Suggestions on a cabinet for Faital Pro 15PR400
