Valve amp - vanishing bass
Hey guys, a gradual lack of bass in my system. Could this be the valves aging ?
The four power tubes I replaced last year, but not touched the 6N1 pre and buffer ones in five or so years.
Any ideas pls as I don't have any valves I can swop and test with.
Amp: Yaqin MC-10L
Administrator
Joined 2004
Hi Barbieboy,
Unlikely bad coupling caps unless they aren't rated for a high voltage. It is more likely that the tubes may possibly be getting weak, and that would also be accompanied with poor sound quality. I haven't got a schematic for that, so I can only talk in general terms. Sorry.
To help us out, is this an old amplifier, or is it recent manufacture? If it's an old amplifier, have you replaced the coupling capacitors yet?
-Chris
Administrator
Joined 2004
Hi Barbieboy,
So that amplifier is new manufacture then. Age related problems will not be your problem.
Did this issue start after you did the "upgrades"? If it has capacitors from cathode to ground, you should also check those.
-Chris
Administrator
Joined 2004
Hi Barbieboy,
At this point you need to actually measure the output some way. You have to run a tone and measure the output to find out where it is really rolling off. Only after then can you look for problems. Otherwise, you won't know whether to look at the speaker (could have a swelled voice coil) or the amplifier. I can't see any common faults in an amplifier that is that new. Even your changes worked for a year before trouble showed up.
One possibility. I can't see the inside of the chassis,so this is a guess more than anything else. is it at all possible that a solder connection has become disconnected? Using your eyeballs is a first step in troubleshooting a problem. Solder joints certainly can fail after a year. Do you take this amp on the road?
-Chris
Thanks guys,
Just had a neighbour pop in and he cranked the volume up higher than I normally do and said "you see, there is bass there". But I don't want to listen that loud, he thinks the problem is the amp is not powerful enough to produce low volume bass (52WPC into 4ohm speakers).
Ok he has a point, but this does not explain why it sounded nice before !
Administrator
Joined 2004
Hi Barbieboy,
Nope, that isn't reasonable. I have a 35 wpc amplifier that drives speakers with low bass notes no problem. If you are playing at low volume, you may need to engage loudness, or turn the bass up a little. Your amplifier should deliver the same power to speakers of 8 or 4 ohms if you are using the proper taps.
-Chris
[1] Make a passive bass-boost circuit. One easy solution if all the rest of the circuit is OK.
[2] If both channels are the same, then it is quite unlikely that there's something systematic going wrong with the amplifier.
[3] How old are you? One of the things that begins to decline less obviously with age is bass ear response. We all know about 'failing treble'. But bass goes too…
[4] Is there a preamp between all your sources and the amplifier? Could easily be something within that, not the final amp.
[5] TRY YOUR CDs on another system, with different 'everything'. Play it at the volume level you like. Is there bass? If so, … then yah… something about your system might be amiss. If not… ears… age… expectations… false memories…
[6] Back in the "old days" one had stereos with 'tone controls'. They're pretty good at boosting bass, if that's what you like. Too bad they're near-gone these days. Just saying...
GoatGuy
Hi Goaty,
[1] don't know how to make one.
[3] 56 and the very same thing went through my mind, and didn't know that...
[4] No preamp, laptop, J.River, Asio, into usb Dac, into amp.
[5] Have no other system, but changed the speakers, made no difference. Wish I had another amp to play with.
[6] Could play with the EQ in j.river. OMG going back to tone controls in old age ? :/
