100W Ultimate Fidelity Amplifier
Nice work... replace C7 with 1000uF/16V instead 100uF/63V to improve 50hz square.
Thanks, you are correct. Here are new scope shots with the 1000uF 16V installed in C7.
Terry i ask about bass responce because this range isn 't the good point for 1058,162
This is my experience.
Strange, that has not been my experience. P101, VSSA, TubSuMo, Slewmaster mini and now FX8, all with great low end. This FX8 has some of the flattest 50hz square waves i have ever seen. There is a tad of overshoot in the higher frequencies. I used 100p per the schematic. Mile's layout seems to use 330p. I don't have those in stock so i stayed with the 100p. I'm not sure if that is the reason.
Output inductor will remove overshoot,
So you can not mix "D" and "E" versions?
mixing the hFE results in a difference in base current when the devices pass the same emitter current.
That mismatch in hFE will happen whether the devices are both D, or both E, or from D & E.
It's the difference in base current that matters.
Will the circuit perform as well if the base currents are not closely matched?
The designer has not told us what effect on performance there would be if the base currents are not matched.
