Chinese board 6L6 KT88 is it worth???
Tube SE 6L6 EL34 KT88 Amplifier Stereo PCB | eBay
I was looking to this chinese boards for tube amplifiers.
As i posted before im new to amplifiers and want to make something simple for starting.Thinking for KT88 for final to get more watts.
Will be this good according to the schematic?or i will throw to the bucket my money.Please remember that i want something good to sound but without toooooo much money,tubes,weight etc.
something to build for the start.
i prefer to give money for good OT.
George
There hasn't happened much in here, but I hope I will stir things up a little. As there's a thread about PCBs for 6L6, EL34, KT88, KT120 ..., I prefer filing my own suggestions and concerns in this thread.
Recently, I purchased this bare PCB from China. It's a sturdy double-sided PCB with goldplated solder pads. It steams quality really.
The design is for a SE-amp using any power pentode/beam-tetrode like 6L6 ... KT120, 807, GU50 ... you name it. Driver is a 6SL7 SRPP/mu-follower OR a 6SN7.
Even as there's a pretty nice schematic and a BOM I run into a few road bumps, that I haven't managed to clear out with the supplier.
One issue is a discrepancy between the schematic for the PSU and what's actually laid out on the PCB and another are some small changes obviously made here and there and that not all components on the PCB are marked with a designator.
One general question - it is suggested that I use a 270 Ohm 50W cathode resistor for a 6L6 (SE) @ 100mA (or propably less). But a 5,5W resistor ought to be enough.
Guess I will have to send another message to the supplier asking for a new and updated schematics. Of course I will get a (good) result following the markings on the PCB, but it will be difficult to make modifications.
The main idea was to fix something "simple" to be able to "listen through" a number of 6L6-like tubes from Russia and China I've got and when finished with that, use the board for either a pair of GU50 or 807.
So simply, has anyone tried this PCB and has any advice. Whenever I get answers from China or has made some progress myslef, I'll be back.
I did the mat (or at least had a sneak view at the answers) and knew that 5W was enough.
On the other hand, the KT88 would require a 25W resistor... 🙄
Let's se if I have a copy of the board somewhere. Oh, am I stupid or just dumb??:headbash: There's pic of the PCB on the sellers eBay-site. The two big square holes (there are four actually) were meant for the BIG resistors, the other for cathode caps.
Two things you might consider.
DIY Single-Ended KT88 / 6L6 / EL34 / 6CA7 Tube Amplifier
Tubelab SSE | Tubelab
I have built the Tubelab simple SE and it is an excellent amp.
I second this motion. The circuit is so simple with such few parts why spend money on a board. My first SET was a simple spud amp but either one of these is just one more tube per channel and I am sure they will sound much better. Many builds have been done with Tubelab boards with tons of support and information on this forum.
Hi, I bought the same pcb from same supplier. Not sure if you get the same schematic, mine shown 150 ohm 25w, but base on calculation, a 5w is more than enough. Also there are 2 track missing, where the vendor said only connect necessary. Some sp also in reverse between the 2 channel
Hi, SB
My PCB did not have label & I trace it & label it myself. Please note C17 one side on PCB has no connection which should be Gnd. Connection between +ve C15 & R27/R30 is missing on PCB.
Numbering (on PCB) of sp5 & sp6 (2 & 3) are in reverse compare with the schematic.
Pin 2 of V4 has no connection to Pin1 of SP5.
I'm still waiting some 2W/3W resistors before I can finish, so still have not test the amp. I'll be using EL34B hence I change the output tube cathode R to 330, if the result is not satisfy, I'll use 220.
Please confirm if you are receiving the same schematic.
  • KT88 SE schematic.pdf
Thanks for your info. Will look into this ASAP. I still have to order components I didn't find in my drawers.
Btww, the SP? is a kind of switch or what? That was something that could be clarified in the BOM.
PeDIYtube has developed some various tube amps with PCBs and I got the board for the Clementine. There are also good info how to use it för 6L6. Had an idea of using that PCB, but it's always a mess order stuff from USA (delivery time, postage costs, delivery time ...).
Clementine
