lm3875 at 94V
hi i dont have enough parts at stash,run out of good transformers and hi curent regulators ,and in sort of hurry to finish amp.at +-45v dc is it better to drop 10v with 2sc1943, 2sc5200 or put them in output(dont care i need pair more i have stash) ,sort of using 3875 as first stage but on 94v still 😀 ? i know neither solution is good but i need to have spare amp in few days from now,so cant wait for parts to arrive.
i think is lot better to put in output but want to make sure i didnt miss something.
ok this should work, i will try this afternoon to make then post if it is working and why not,but i will use 3875
Absolute maximum ratings are 94V rail to rail when no signal is present and 84V rail to rail when a signal is present.
Your measured 94Vdc may not be worst case.
How high could that go when mains is at it's highest?
I suggest that you build a non feedback voltage regulator using a Zener and emitter follower (Pass has examples) to bring your supply down to +-40Vdc, or lower.
A capacitance multiplier could also drop significant voltage to enable your chipamp to survive.
hm, interesting solution. but does bucking transformer has to be same primary wire diameter as transformer i am connecting it to? i sort of need to order some parts now so i will probably order 20 or so lt1083 and that is sort of easy solution to me as i have bigger heatsink stash than good transformers stash.
