I am having a problem with this amp. This amp does not have a balance pot but individual volume pots. The problem is the right channel is much softer than the left. If I set the left channel level at quarter, I have to set the right channel level at more than half to make it sound balanced. I checked the volume pot (50KA X 2) and it is OK. I removed the 2 links between "pre out" and "main in" and plug a signal into the 'left main in" and 'right main in' and the left sound louder than the right. I guess it means that it has nothing to do with the "pre out". I checked all the components on both the power amp boards, all seem to be OK except that resistor R669(10 ohms, 3 watts) has blown, but this resistor is on the left channel which is working OK. I am confused. Can this resistor be the problem. Please help.
Carlos
Carlos
That sounds like the amplifier has reduced gain and the 'good' channel has a burnt out Zobel resistor. Check the feedback decoupling capacitor.
Will do. Thanks
Carlos
Will do. Thanks
Carlos
Hi JonSnell,
On checking again, I realised that I have overlooked another resistor that has also blown. R620 (562 ohms) on the problematic channel was open, after replacing it now the amp is back to normal.
Many Thanks
Carlos
