I have just purchased two PA-460 18" Woofers. The dealer has a sale on these for $90 till the 31st and theres a Coupon for $5 off.
Dayton Audio PA460-8 18" Pro Woofer
I was thinking of building a box 36" tall with roughly 6.5cu Ft. Working out to around 18x18x36.
The lowpass filter will be at 250hz, and I will be using 3-5" drivers to cover the midrange on a Unity horn.
What Frequency should I tune the box to?
Should I use two 4" ports or build a vent across the bottom?
Thiele-Small Parameters
Resonant Frequency (Fs)28.3 Hz
DC Resistance (Re)5.6 ohms
Voice Coil Inductance (Le)3.9 mH
Mechanical Q (Qms)11.2
Electromagnetic Q (Qes)0.34
Total Q (Qts)0.33
Compliance Equivalent Volume (Vas)14.19 ft.³
Mechanical Compliance of Suspension (Cms)0.19 mm/N
BL Product (BL)22.3 Tm
Diaphragm Mass Inc. Airload (Mms)171g
Maximum Linear Excursion (Xmax)6 mm
Surface Area of Cone (Sd)1241.1 cm²
Total Q (Qts)0.33
