Having trouble finding a resistor for my reciever and I'm lost without it.
P H R
MPR 5W
R22J X2
Any help is appreciated!
P H R
MPR 5W
R22J X2
P H R
MPR 5W
R22J X2
Picture?
it was center pin common and a triple pin setup plate resistor
The markings suggest that it may be a dual 0.22 ohm 5 watt resistor.
You could then replace it with 2 resistors, one lead each soldered together for the required 3 terminals.
These show up in the emitter circuits of SS output stages, and are prone to be fried when there are other failures in the circuit. I'd expect to find one or more fried transistors in the same amp channel.
