If you need 100 mA out, 200 mA rating for the transformer would be OK.
Thank you!
Do not use a torroid, (they have too wide a bandwidth and pass too much AC line noise. use a split bobbin type or an R core , but don't use a torrid. Use a full wave bridge on each winding and create the DC ground from the positive terminal of the negative bridge and the negative terminal of the positive bridge to reduce ground loops.
Any number on this? How much is much?Do not use a torroid, (they have too wide a bandwidth and pass too much AC line noise..
Does anyone care to discuss this?
From an old message in this thread:
Thanks in advance.
If you look into the schematic you also will see nothing special in the audio path, there is a lot to improve for example better coupling caps, opamps etc.
Thanks in advance.
- Group Buys
- Group Buy: SSR03 Super Regulator Power Supply
