So 4 ohms is really the way to go then, right?
There is not really a right or wrong way, just what sounds best to you. I am assuming you are talking about a tube amp. For all intense in purposes the speakers are supposed to be hooked up to a SS 8 ohm connectors but with tubes and OPT's it could work best either way. Even with SS I see no problem having it hooked up to the 4 ohm connections.
Posted by djk on 12 February 2015 - 02:02 AM in 2-Channel Home Audio
"So are you saying that you can get better sound on the 4 ohm tap with Klipsch speakers and tube amps?"
At low volumes a speaker always plays loudest on the 8 and 16 ohm taps. As you turn up the volume and 'thump' it a bit you will find the speaker sounds the best on the tap that closest matches its impedance, and plays the loudest too.
Always try the 4 ohm tap. Leave it on whatever sounds the best.
Hint: it sounds 'thin' when you turn it up if you have it hooked to too high of a tap.
Easiest way to check LF driver phase is to stick a 1.5V battery across the terminals and see which way the cones move. Simple and infallable.
To make some cross-references:
https://community.klipsch.com/index.php?/topic/149779-klipsch-heritage-woofer-ts-spec-v17/
Klipsch crossovers:
https://community.klipsch.com/index.php?/topic/113804-klipsch-crossovers/
T2A autotrafo:
https://community.klipsch.com/index.php?/topic/113804-klipsch-crossovers/#entry1282294
Drivers parameters:cornwall
Frequency Response: 38Hz-20kHz(+-)5dB SENSITIVITY: 98.5dB @ 1watt/1meter POWER HANDLING: 105 watts maximum continuous (1000 watts peak) NOMINAL IMPEDANCE: 8 ohms TWEETER: K-77-M 1" (2.54cm) Phenolic diaphragm compression driver HIGH FREQUENCY HORN: 90(o)x40(o) Exponential Horn MIDRANGE: K-55-V 2" (5.08cm) Phenolic diaphragm compression driver MID FREQUENCY HORN: 90(o)x40(o) Exponential Horn WOOFER: K-33 15" (38.1cm) Fiber-composite cone ENCLOSURE MATERIAL: Birch Plywood or Veneered Lumbercore ENCLOSURE TYPE: Bass reflex via front-mounted port DIMENSIONS: 35.75" x 25.5" x 15.5" WEIGHT: 108 lbs. FINISHES: Walnut, Rose, Teak Oil, Oak, Cherry Lacquer, Natural, Mahogany, Maple, Raw, Black Birch Built From: 1959 BUILT UNTIL: 1985
https://community.klipsch.com/index...sch-heritage-woofer-ts-spec-v17/#entry1724699
Klipsch crossovers:
T2A autotrafo:
Hello,
I just purchased a pair of Cornwalls with the B3 crossover, 1983 I believe.
Pictures of the crossover please.(...)
I am having some problems with the bass sound. Its there and its clean, but it just doesn't seem to be in balance with the levels of the high end. I want to keep turning up the sound to bring the bass out, but obviously that turns up everything (the bass preamp adjustment also doesn't fit my tastes). Maybe I am just not used to such high end speakers, but in a way my chest kind of feels empty when listing because i want some more low end to balance with the high end. So I was wondering if this was typical of the Cornwalls...
Investigate if the components (4mH coil) is the original.
I am not sure about the Cornwalls but my LaScala's are 4 ohm woofers, 16 ohm mids, and 8 ohm tweets but the overall specs are called 8 ohm. And actually that is not the exact impedance of the drivers and as most know the impedance changes with the frequency. There would nothing wrong using the 4 ohm tap on your amp if that is what you like best.
Klipsch used four-ohm woofers in their bass horns because they claimed that horn loading increased the impedance. Since the Cornwall has ported bass, I expect they used an eight-ohm woofer.
The Cornwall uses the same woofer as the La Scala and the Khorn.
Look again at the impedance curve: http://www.diyaudio.com/forums/multi-way/283445-klipsch-cornwall-sound-question-2.html#post4542632
I don't know why this is an issue for this thread's topic. Here is an impedance plot of the Khorn done by Richard Heyser--showing the impedance rises in the bass bin below 400 Hz.
Chris
- Klipsch Cornwall Sound Question
