Guillotine - son of Geriitts reductio ad minimum ribbon
3rd looks good actually. Now for the final assault...
Fail. Major. While setting pressure on the 4th magnet it came to rest on one of the ridges and snapped. Not only did no 4 break but also no 2 on the opposite side. Thats a bit of a problem as I don't undertand how I can get rid of the magnet... This is a bit challenging on the kitchen floor. But I'm not giving up just taking a bit of a break. Have now 4 broken magnets. Need also guides in the other direction but this is a bit trickier...
But this is all very good as I plan to make also shorter ribbons 😉
Here are five very powerful magnets more or less safely handled, ready to be slid off to another location.
The poles of the magnets are all oriented the same--therefore they tend to repel on the steel backing (which is 3/16 inch thickness). General rule is that the back side of the steel plate should not be very magnetic--this implies that it is short-circuiting most if not all of the magnetic lines of force. That is why it is safer. Obviously disaster can still strike if you get something above the magnets and drop down. That is what common-sense is for.
I managed to get rid of the magnet. It was not so hard witch make me question my glueing technique. I sand the carbon and wipe with acetone. The magnets I wipe with acetone, apply epoxi and sand in the wet epoxy - 150 grit.
Anybody have a hint how to separate these two?
OK the thing came out of the jig in one piece. Then this morning I performed the test I had promised myself - the kitchen floor (soft mat) 50cm drop test. It survived the first gentle 30 cm but at 1/2 meter, 2 magnets on the same side ... changed side 🙂 ...in halfs.
So now I have learned a lot and need to start do things really correct e.g. use not 5 min Epoxy but the real stuff.
But now I'm confident in placing and clamping magnets so thats good :-D
I will now take a few days rest from this endeavor.
erm on purpose ? 🙁 all the work and magnets
usually those hard glue's are not that shock resistant. if you want to redo the test look for a glue that is 🙂
i dont think it must be able to fall. i mean even magnets from loudspeakers come of if you let the cabinet fall. just wear some safety goggles when aligning cant hurt you 🙂 but does save you soem time and money 🙂
I Dont know, i have no clue. Impact resistance you neef for your test 😉 , neodymium are hard to adhire there surface Is so smooth, and it's under tension permanent. I used cyanoacrylate glue but that's sucks to. hit it an they will come appart. I chose this for a reason so I did not have to throw away everything when I wanted to try something different. I think epoxy is pretty common to use. Just don't throw with it 🙂
Slow dry 2 component epoxy tends to adhire better then the 5 min stuff. And slightly roughing the surface without sanding away there coating . Then clean with alcohol and glue them with slow set epoxy . Have patience ( mr saying this is insane)
