Max voltage across microphone signal transformer.
Hello,
I have some NOS mic preamp microphones with a 15k:600R impedance ratio. I was thinking of using them in a parafeed configuration as an anode load for a tube preamp. The problem I thought of is when B+ is applied, the parafeed capacitor conducts until charged and a big voltage impulse swings across the primary. For now, I have three "audiophile" ways to resolve this problem.
1. Rectifier tube heater (auto) soft start
2. Smart soft start - using somewhat larger PSU capacitors, so the B+ ramps up slowly enough to not let an excess swing on the parafeed capacitor
3. Shunt resistor across the primary with an automatic "mute" NC relay.
And lastly, do you think these microphone transformers can withstand voltages such as 100-200V, or I shouldn't risk?
Alexander.
A true slow warm-up rectifier may be ok, but check the turn-off transient as well.
A muting relay across the primary, enabled after warm-up, and muting upon switch-off, would be safest.
I have a 555 timer circuit that is well tested, if you'd like to do that.
Don't assume anything about the voltage rating, as it could be as low as 50V to 100V.
The transformer will see no more than 6V RMS of swing (17V p-p) across its primary. On the secondary this will appear as 1,2V RMS. I will measure it if it saturates. But I doubt the insulation will break on even 20V p-p.
The only thing that worries me are the transient voltages when the capacitor charges. A mute resistor and relay is pretty easy to do.
