epoxy for bonding sheet metal to plywood?
Ive used epoxy for just about everything else but. Its for a base consisting of 1/8 stainless steel and pine board then trimmed out. Although I think I will get some ply I think it will work better in every way for intended purposes.
As Conrad implied, if the metal surface is polished and not obsessively degreased and dried, the Epoxy adherence won't be great, I suggest sandblasting it and then proper degreasing, at least with some clean solvent but even better with some Industrial detergent, which will leave no residue.
As also suggested, solvent based contact cement might work better simply because of 2 factors: solvent dissolves any residual oils (even touching surface with bare hand will contaminate it) and being slightly flexible, will resist possible bending and impact better.
Sorry for not covering everything. The steel was never used it still had the plastic on. there are no contaminants other than prints. I could also give it a wipe with disc brake rotor cleaner. I think I might try the cement. Im pretty confident it will be on there for good. Time as always will tell.
Most important prep for epoxy on steel is sanding with #80 grit. (Also being clean but that was already mentioned).
Also there are some epoxies especially formulated for dissimilar material joins, e.g. West G-flex. Follow instructions and joint will last forever.
Its meant for an audio base that will have an amp on it, or other device. So it wont be subject to any negative g's that might potentially pull and tear the two surfaces apart upon re entry.
Check on the 80 grit. I planned on roughing up the two surfaces before any permanent or non permanent bonding takes place.
Does the cement dry as the name would imply? I remember some stuff I was in contact with having more of a hard rubbery like feel to it. It wasnt sillycone, no mistaking. I suspect there could be different types. Since it is audio related vibration cancellation will be my friend here.
Epoxy is more fun to play with. I'm really back on the fence here now fella's.
Here's a little bit about gflex epoxy, it has a little table showing prep work:
WEST SYSTEM - Projects - WEST SYSTEM launches G/flex Epoxy
Most manufacturers have similar products. Note that this is not "just" epoxy it has special additives. I only recommend because I have used it, primarily for aluminum to carbon fiber, but also for steel. Is this stainless steel? That is harder. But if its not a structural bond many adhesives will work.
If this is important to you then experiment on a trial piece first.
