The Well Tempered Master Clock - Building a low phase noise/jitter crystal oscillator
New update
jborden, Stijn001,
your order form was updated.
Following the updated interest list for SC-cut and AT-cut crystals from Laptech. The star before the alias means that I have received the order form.
I will provide to send a PM to the members who have not yet sent me the order form. Attached the updated Order Form.
I will update the first post, adding the link to the Order Form sheet.
Interest List SC-cut Crystals from Laptech
- * andrea_mori: 3 x 11.2896 MHz + 2 x 22.5792 MHz + 2 x 24.576 MHz + 1 x 45.1584 Mhz + 1 x 49.152 MHz
- Acko: 1 x 45.1584 MHz + 1 x 49.152MHz
- iancanada: 1 x 22.5792 MHz + 1 x 24.576 MHz + 1 x 45.1584 MHz + 1 x 49.152MHz
- Clsidxxl: 1 x 45.1584 MHz + 1 x 49.152MHz
- lindamar: 1 x 11.2896 MHz 1 x 22.5792 MHz + 1 x 24.576 MHz + 1 x 45.1584 MHz + 1 x 49.152MHz
- * tagheuer: 1 x 45.1584 MHz + 1 x 49.152MHz
- palmito: 1 x 45.1584 MHz + 1 x 49.152MHz
- damohpi: 2x 11.2896 Mhz
- Naimster: 1 x 22.5792 MHz + 1 x 24.576 MHz
- Phi: 1 x 22.5792 MHz + 1 x 24.576 MHz (Added title )
- ambrosia168: 3 x 11.2896 MHz + 3 x 45.1584 Mhz + 2 x 49.152 MHz
- * flowerpot: 1 x 45.1584 MHz + 1 x 49.152MHz + 2 x PCB + 1 x daughter board + 2 x DIL
- jdlvfr: 2 x 11.2896 Mhz
- tods: 1 x 22.5792 MHz + 1 x 24.576 MHz + 1 x 45.1584 MHz + 1 x 49.152MHz
- wlowes: 1 x 45.1584 MHz + 1 x 49.152MHz
- * fralippo: 1 x 45.1584 MHz + 1 x 49.152MHz + PCBs
- * duster1: 1 x 45.1584 MHz + 1 x 49.152MHz + 1 x 90.3168 MHz + 1 x 98.304MHz + PCBs
- deanoUK: 1 x 45.1584 MHz + 1 x 49.152MHz
- * BDL: 1 x 22.5792 MHz
- * vita : 1 x 45.1584 Mhz + 1 x 49.152 Mhz
- Malvin: 1 x 45.1584 MHz + 1 x 49.152MHz
- rlim: 1 x 22.5792MHz + 1 x 24.576MHz
- Canvas: 1 x 11.2896 MHz + 1 x 22.5792 MHz + 1 x 24.576 MHz + 1 x 45.1584 Mhz + 1 x 49.152 MHz
- * mcluxun: 1 x 45.1584 Mhz + 1 x 49.152 MHz
- grzegrzol: 2x 11.2896 2 x 22.5792 MHz + 2 x 24.576 MHz + 2 x 45.1584 MHz + 2 x 49.152 MHz
- * jims: 1 x 11.2696 Mhz + 1 x 45.1584 Mhz + 1 x 49.152 MHz
- * madkid 1 x 45.1584 Mhz + 1 x 49.152 Mhz
- * tbrowne 2 x 22.5792 MHz + 1 x 24.576 MHz + 1 x 45.1584 MHz + 1 x 49.152 MHz + 1 x 90.3168 MHz
- * jborden: 2 x 45.1584 Mhz + 2 x 49.152 Mhz
- * Stijn001: 1 x 45.1584 MHz, + 1 x 49.152MHz
Second batch AT-cut Crystals from Laptech
- * andrea_mori: 2 x 6.1440 MHz + 2 x 12.2880 MHz + 1 x 16.9344 MHz
- Miklos: 1 x 16.9344 MHz
- Marlowe: 3 x 16.9344Mhz + 3 x 25MHz
- carz 1x 27MHz
- 1audio : 1X6.1440MHz
- * mravinsky : 2 x 16.9344Mhz + (2 x TWCMC-C XO board +1 x daughter board) if possible
- * noizas : 2 x 16.9344 MHz
- randytsuch: 2x 25.0000 MHz
- casshan: 1 x 11.2896 MHz + 1 x 12.288 MHz + 2 x PCB + 1 x daughter board
- Fabian85: 1x 16.9344 MHz, 2x PCB + 1x daughter board
- * duster1: 2 x 16.9344 MHz, 1 x 45.1584 MHz, 2 x PCB + 2 x daughter board
- * RollE2k: 1 x 45.1584 MHz + 1 x 49.152MHz + 2x PCB + 2x daughter board
- * shendrik: 2 x 22.5792 MHz + 2 x 24.576 MHz
- babaudio : 4 x 22.5792 MHz + 4 x 24.576 MHz
- Justubes : 1 X 25mhz
- grzegrzol : 2 x 16.9344 MHz + 2 x 22.5792 MHz + 2 x 24.574 MHz + 2 x 25 MHz 2 x 45.1584 MHz + 2 x 49.152MHz
- * jborden: 2 x 25.000 Mhz + 2 x PCB
- smanz:1 x 45.1584 MHz, + 1 x 49.152MHz, 1x TWTMC-D&D, + 2x TWTMC-C
- * jims: 1 x 6.1440 Mhz + 2 x 16.9344 MHz + 6x TWTMC-C +3x TWTMC-D&D + 6 x TWTMC-DIL
- * madkid 1 x 90.3168 MHz + 1 x 98.304MHz + 4 x PCBs
- * tbrowne 5 x 22.5792 MHz + 3 x 24.576 MHz + 1 x 45.1584 MHz + 1 x 49.152 MHz
For the following frequencies, the MOQ was reached:
SC-cut 11.2896 MHz (15)
SC-cut 22.2792 MHz (14)
SC-cut 24.5760 MHz (12)
SC-cut 45.1584 MHz (28)
SC-cut 49.1520 MHz (27)
AT-cut 16.9344 MHz (16)
AT-cut 22.2792 MHz (13)
AT-cut 24.5760 MHz (11)
AT-cut 25.0000 MHz (10)
For the following frequencies, the MOQ was not reached:
SC-cut 90.3168 MHz (2), MOQ 15 pcs
SC-cut 98.3040 MHz (1), MOQ 15 pcs
AT-cut 6.1440 MHz (4), MOQ 15 pcs
AT-cut 11.2896 MHz (1), MOQ 10 pcs
AT-cut 12.2880 MHz (3), MOQ 10 pcs
AT-cut 27.0000 MHz (1), MOQ 10 pcs
AT-cut 45.1584 MHz (6), MOQ 10 pcs
AT-cut 49.1520 MHz (5), MOQ 10 pcs
AT-cut 90.3168 MHz (1), MOQ 15 pcs
AT-cut 98.3040 MHz (1), MOQ 15 pcs
Please, keep in mind that this is not a commercial project, I supply crystals and PCBs at cost (first batch I lost money).
So, I don't stock any crystal. I place a new order to the manufacturer when there is enough interest.
Moreover, for each crystal frequency we have to reach the MOQ required from the manufacturer before I could place a new order.
Since crystals are expensive and I have to pay in advance, I will place an order as soon as I receive all the payments.
Following available frequency for AT-cut and SC-cut crystals, their price and their MOQ:
SC-cut crystal
11.2896 MHz 3rd overtone MOQ 15 pcs Eur 38.00 each
22.5792 MHz 3rd overtone MOQ 10 pcs Eur 38.00 each
24.5760 MHz 3rd overtone MOQ 10 pcs Eur 38.00 each
45.1584 MHz 5th overtone MOQ 10 pcs Eur 38.00 each
49.1520 MHz 5th overtone MOQ 10 pcs Eur 38.00 each
90.3168 MHz 5th overtone MOQ 15 pcs Eur 56.00 each
98.3040 MHz 5th overtone MOQ 15 pcs Eur 56.00 each
AT-cut crystal
5.6448 MHz fundamental MOQ 15 pcs Eur 29.00 each
6.1440 MHz fundamental MOQ 15 pcs Eur 29.00 each
11.2896 MHz fundamental MOQ 10 pcs Eur 27.00 each
12.2880 MHz fundamental MOQ 10 pcs Eur 27.00 each
16.9344 MHz fundamental MOQ 10 pcs Eur 27.00 each
22.5792 MHz fundamental MOQ 10 pcs Eur 27.00 each
24.5760 MHz fundamental MOQ 10 pcs Eur 27.00 each
25.0000 MHz fundamental MOQ 10 pcs Eur 27.00 each
45.1584 MHz 3rd overtone MOQ 10 pcs Eur 27.00 each
49.1520 MHz 3rd overtone MOQ 10 pcs Eur 27.00 each
90.3168 MHz 5th overtone MOQ 15 pcs Eur 29.00 each
98.3040 MHz 5th overtone MOQ 15 pcs Eur 29.00 each
About the PCBs
The TWTMC-C board is a Clapp oscillators suitable for AT-cut crystals only. There is an issue with 90/98 MHz crystals, the oscillator doesn't start at the right frequency. I'm still working to solve the issue using a different active device (higher transconductance).
The TWTMC-D&D is the daughter board that can accommodate 2 oscillators. It provides the power supply for the oscillators, some clock dividers, some delayed clock and the logic to switch between the 2 oscillators. This board will be useful also for Sc-cut oscillator board, including the power supply for the ovens.
The TWTMC-DIL board is an interface to connect the oscillator to Ian's dual clock board.
PCBs:
TWTMC-C (XO, not suitable for SC-cut crystals):
Size 1.75" x 1"
Board thickness 1 mm
Copper weight 70 um (2oz)
Surface finish Ni/Au
Unit price € 2
TWTMC- D&D (Daughter board):
Size 4.25" x 3.25"
Board thickness 1.2 mm
Unit price € 9
TWTMC- DIL (Adapter board):
Size 0.7" x 0.5"
Board thickness 1.6 mm
Unit price € 2
Work in progress
I'm working on 2 new boards:
The TWTMC-D board is an emitter coupled oscillator (Driscoll), suitable for SC-cut crystals. It could be used also for harmonic AT-cut crystal (from 33 to 98 MHz).
The TWTMC-OVN board is an oven to be used with the Driscoll XO board and SC-cut crystals, that need to operate at a costant high temperature. It could take power supply from the TWTMC-D&D daughter board.
At this moment the above PCBs are not available, I will order some prototype next days.
BTW, to test them, I have to get SC-cut crystals, so we have to reach the MOQ for each frequencies, I have to receive all the order form and all the payment, then I can place the new order. After, when I will get the crystals, I will test the boards. After the tests, the PCBs will become available.
I hope it was all clear.
Andrea
add 1 SC-cut 11.2896 MHz
- jdlvfr: 3 x 11.2896 Mhz
- carz 1x 27MHz
PM have been sent to all the members who are in the interest list, but haven't yet sent me the filled order form.
Since I would finalize SC-cut and AT-cut crystals order as soon as possible, please download the order form spreadsheet (post #761), fill and send it me back.
@Justubes, you cannot receive message, so if you read this post, please send me the order form.
Andrea
Driscoll Oscillator
The Driscoll oscillator doesn't show up in the usual listings of crystal oscillators. its from an article by Mr. Driscoll in 1973 (IEEE transactions). I did some homework I'm sharing for those who aren't familiar with the Driscoll oscillator.
I ran across this dissertaion : https://scholar.sun.ac.za/bitstream/handle/10019.1/1628/BentleyB.pdf?sequence=1 which has a good description of how to optimize the design of a Driscoll oscillator. This and Driscoll's presentation on oscillators http://www.ieee-uffc.org/frequency-control/learning/2003_IEEE_Tutorial.PDF are really good resources.
The key magic of the Driscoll oscillator is putting the crystal in the emitter of a common emitter amplifier which maximizes the effective Q of the crystal and minimizes its phase noise. That plus an AGC get the best results. I'm looking forward to Andrea's results.
Order form sent. I changed my request quantity.
- Canvas: 1 x 45.1584 Mhz + 1 x 49.152 MHz
- carz 1x 27MHz
Removed myself from the list. I have just to many unfinished projects.
- carz 1x 27MHz
Demian,
thanks for the useful links.
This is the original patented circuit from Driscoll and Healey in 1974
Patent US3836873 - Low noise vhf crystal harmonic oscillator - Google Patents
I'm working on the simplified circuit that uses a single device as in the Krieger-Matthys pubblication "Crystal Oscillator Circuits" (page 235).
Order form sent. Changed quantity.
- * ambrosia168: 1 x 22.5792 MHz + 2 x 45.1584 Mhz + 2 x 49.152 MHz
- carz 1x 27MHz
I deleted myself from list
- carz 1x 27MHz
Adding 45 + 49 SC-CUT XOs
- carz 1x 27MHz
- Eldam : 1 x 45.1584 MHz + 1 x 49.152 MHz
Hello Andrea,
Can you please tell me the number of optional boards and which one are needed to use the sc-cut XOs both with the first boards of the projects and also for Ian Dual-clock ?
I mean with a pair of OCXO sc-cut I can swap from your boards to the Ian's one when I want to.
2 x TWTTMC-DIL I assume + the ovens boards I assume ?
Thanks you a lot in advance,
Best regards,
Sorry, finally too much projects for the moment. I remove my name, I didn't finish the AT-Cut assembly yet !
- carz 1x 27MHz
Updated and remove items from 2nd batch AT-cut
- * MadKid: 1 x 24.576 MHz + 1 x 45.1584 Mhz + 1 x 49.152 Mhz + 1 x 90.3168 MHz + 1 x 98.304MHz + 6 x PCBs (D + OVN + DIL)
- carz 1x 27MHz
I've sent Andrea the global datasheet for concerned GB members.
Each config is particular, it takes time to check all options.
Work is on the way, waiting for Andrea's answer.
As I've sent it right now, please be patient.
I'm close to send Paypal request before ordering parts.
Phil
- carz 1x 27MHz
Romoved from list
