I like it very much,make a show
1.F5 turbo v3
2.Aleph Mini
3.A3
4.A5
6.Power of F5 turbo
any body like it?
1.F5 turbo v3
2.Aleph Mini
3.A3
4.A5
6.Power of F5 turbo
any body like it?
Beautiful ! ...now finish one of them and make music. 🙂
Glad you made good use of my pcb design for the F5 T V3.
Fill the PCBs with resistors first, then power resistors, then small caps and so on. Install transistors last. Also mount power resistors off the board so air can get around them.
Which one to build?
I'm inspired to build one of those Pass amps. I'm building dFonken ff125wk. I think 10-20 watts could be more than enough for me. Which one would you recommend me?
How skilled you are?
low end? try F5 it is really easy if you follow instructions.
I have an Aleph J this is the amp i would not sale (at the Moment😀)
or Look at M2 this could also be a good alternative.
(all firstwatt amps)
Since my childhood I have build different kinds of electronics, using PCB CAD software and toner transfer method, including 100W amplifier. But I'm not so much skilled as many people in this forum.
Once I've build a A-Class amplifier far 10 years ago. But it was not so good in terms of distortion and noise. But it was first time I met a A-Class amp.
Currently I'm using D-Class 2x100w amplifier board from Sure Electronics. As I'm a little "conservative" person and I like "tech-porn", I would like to build some nice A-Class amp, but a good sounding one.
P.S. I have found Pass F5 BCB boards on eBay from China. Are they lisenced? Is it worth to buy KITs from there?
you are better off geting the PCB's fro diyaudio store. you can get transistor kit inkl J-fet's from member h_a.
Asa far as I know the only authorized PCB's for pass projects are the ones from the diyaudio shop or the ones from group buys authorized by Nelson. The bay ones are probably made without authorization from Nelson and you might risk getting fake parts in the kits as well.
...I would like to build some nice A-Class amp, but a good sounding one.
You could build it Perf Board -solid as a rock-
-->look
Or what i would do if i could build my F5 again.
I would try to do it like an Fender Amp with a turret board -rock solid too-.
Amp is easy enough for such a build.
- My AM A3 A5 F5 turbo v3 PCB show
