Good luck getting the JFETs.Attached is one designers jfet/ne5534 implementation?
I posted it one time in a diyaudio thread and one person commented that it can't be any good for audio, it is only good for a THD analyzer use 🙂
One day I will lay it out in smt to give it a try. It so hard to judge the differences between these low THD designs.
I would think paralleled Linear Systems duals would work fine.
You should be able to use two parallel BF862, xSK170, or similar JFETs, per half of a 2SK146 and get very close to the original. Edit: was too slow.
Mr Wood, how unsooth of you.
I've had obsolescence on my mind of late. I no sooner tell a contract manufacturer how much I hate single-sourced components than the options evaporate.
Edit: was too slow.
Me too. (single-handed webcam must be a b...)
Too slow most of the time but not always:
And I really should have said discontinuance, not obsolescence. The latter means something is no longer desired, which is not the case most of the time with electronic parts --- unless it applies to the decision-makers at the parts houses.I've had obsolescence on my mind of late. I no sooner tell a contract manufacturer how much I hate single-sourced components than the options evaporate.
Parts porn. My webcam is disabled or I would show my box of 2SK389V.
http://www.richardhess.com/manuals/Amber3501.pdf
The rest of the manual (on a quick look) is also not bad for theory of operation.
I have a reputation for finding a new part and everyone here telling me it will soon be EOL based on my past history. Now I just buy them all.
I have a reputation for finding a new part and everyone here telling me it will soon be EOL based on my past history..
Does Nelson know you talk about him like that 😛
(sorry couldn't resist. It is friday after all) 🙂
why resurrect these circuits - recent op amps have much better output stages with faster, better matched complementary Q
show discrete fet input with something from only the last 20 years, please
yes you don't have as many options today to cut off/bypass the input in the following op amp - but many can be had so many times faster that you wouldn't need to to exceed a 5534 composite circuit
Unless you obsess over the ~1nV noise.
awkward wording on my part - I was trying to ask why don't people show discrete fet inputs with modern op amp following them
trying to point out that the modern op could be selected to be so much faster than a 5543 with disabled input replaced by discrete fets that you could still compensate the discrete fet+series modern op amp multiloop to give a faster composite amp than the fet+5534 despite not being able to bypass the modern part's input stage, having to accept the "extra" stage in series
get the discrete fet noise - and modern op amp output
I meant my comment originally to mildly take a jab at the 5532 haters. Of course, updating these old circuits with modern, high speed opamps would be prudent, even without bypassing the input pair. The biggest benefit I could imagine is stability (distortion/etc has got to be beyond audible).
Certainly provides me with some entertainment 🙂 in my retirement.why resurrect these circuits
As Bob Cordell documented in the lsk489 app note. More circuits for me to try out. pcbway has the $13 per 100x100mm pcb special for 2 layer, how cheap is that to make some toys to play with!!I was trying to ask why don't people show discrete fet inputs with modern op amp following them
WTF...This won't lay shite. Bill this is beyond my limit of eccentricity, sad if you know the whole history (few do).
https://www.youtube.com/watch?v=HRcgQ_e3w4g
- Member Areas
- The Lounge
