No what is PVC? 🙂. Around here you mark things with "iron pins". Just so you can locate them later. But of course you knew you can't dowes for plastic either.
I wrapped critical points with bundles of 12p nails before I closed up the walls.
If anyone is interested Luca Turin's wikipedia page is slightly more balanced than Charles. https://en.wikipedia.org/wiki/Luca_Turin. Would seem Jury is still out on vibratory olfaction.
They were "water witching." That's what they called it.No what is PVC? 🙂. Around here you mark things with "iron pins". Just so you can locate them later. But of course you knew you can't dowes for plastic either.
Are you suggesting the dowser you saw made use of those iron pins? Someone could mistake your condescension as an admission.
Notice the exclusive use of DBT for testing theories.
My guy found metal pipes only one carried water.
If smell exploits QE, why does the rest of our nervous system not use it? AFAIK, signal transmission in animals is electrochemical - my son's GF is a physiologist and I got 101 type intro onto how some pain killers work . . . Which reminds me, I need to take a few since Scott mentioned the myrtle blocks.
Yup, and just think of the audio analogies.Even if you know that dowsing is no better than guessing, if you call in a dowser either:
a. He guesses right and you look like a genius, or
b. He guesses wrong and he looks bad while you can shrug and say the dowser told you where to dig.
The rational thing is to hire the dowser (with the client's money) and shift the blame to the dowser.
All it needs to round it off is 'the wife in kitchen' to confirm she had a feeling that was the right place to dig..............🙄
Got it. Assert something without evidence enough times and it becomes true.
That was Goebbels' approach, no?
se
So you choose to believe on the basis of your anecdotal perception that your dowser could not possibly have intelligently guessed? Overriding and ignoring decades of vigorous study to the contrary, your perception must be right............... seem familiar in audio terms? It seems to be an audiophile thing, no idea why.........🙄My guy found metal pipes only one carried water.
Or to paraphrase J. V. Stalin:
Swindle one, you are a felon.
Swindle a million, you are a famous designer.
No but the simplest explanation is that I don't know what caused the rods to move. The result was accurate.
The crew doing the work seems to think not everyone can do it, but trust their guy.
The World Needs ! ...... John Curl Using These :
http://www.onsemi.com/pub_link/Collateral/EN3309-D.PDF
Please silicon is NOT sand.
Silica, Silicas, Silicates, Silicium, Silicon, Silicone, Silly Cons and Silly Cones, it's all very confusing.
LA4425A
But besides one obvious typo, it looks like the equivalent input voltage noise density is only about 4.8nV/sq rt Hz. I wish some of the more exalted integrated power amps were as quiet.
What a strange datasheet.
se
The thing I like is no need for Zoebel on out ....
cap in cap out .... attenuate as wanted (given 45db)
I recently extracted some fairly impressive performance out of a ancient part by running in low-gain inverting mode, and using enough high-frequency noise gain to sidestep instability. Less than 6uV rms unweighted audio-band noise, quite low distortion. So what if it requires a lot of volts to drive and some reasonable currents? In this case those criteria were readily met. I would say more but the project is under NDA.The thing I like is no need for Zoebel on out ....
Probably expectation bias, it's pretty pervasive in life. The guy likely wouldn't even know it was happening............I don't know what caused the rods to move.
- Member Areas
- The Lounge
