RH0256R000FE02 | Vishay RH Series Axial High Power Wire Wound Resistor 6Ω 1% 25W 50ppm/C | Vishay
Is this resistor usable in a crossover? it seems to be the only findable 6 ohm resistor. Building a pair of overnight sensations... or would it be ok to swap for a 5.6 or a 6.2
Yes you can use it ... it might be a bit 'overkill' but that is never a bad thing 🙂
5,6 ohm and 6,2 ohm are also very close values (6,2 ohm is closest), so without knowing what speakers you are building, I would say that you should not be able to detect any big differences in th sound
Yes sure, it is a good wirewound resistor. Just keep in mind that the 25w rating only applies when it is mounted on a heatsink. In free air it is derated to 9w (according to datasheet).
It has to be on a heat sink for anywhere near full rated power.
You could also use two (of another type) 12 Ohms resistors in parallel, those are common.
Just parallel 2 each 12 Ohm resistors and you have 6 Ohm, if you use the 25W cement Wire wound resistors you'd end up with a 50W 6 Ohm resistor.
Best of Luck
Best of Luck
Resistors are the place to cheap out on XO builds- sandcast/cement are fine. The slight inductance is rarely an issue unless you're doing significant very high frequency shaping, and even a few non-inductive sandcasts (paralleled to right value, and several for power handling) are very cheap relative to a decent coil.
If the 5.6 or 6.2 are lower priced, you can use the 5.6 in series with an 0.4 ohm, or the 6.2 in parallel with a 1/(1/6-1/6.2)=186 ohms. Do the second, a 180 ohm resistor will be cheaper and more available than a less-than-1 ohm resistor, and either only needs to be rated at 1/2 or 1/4 watt or so.RH0256R000FE02 | Vishay RH Series Axial High Power Wire Wound Resistor 6Ω 1% 25W 50ppm/C | Vishay
I found the schematic here:
https://f48a8583-a-62cb3a1a-s-sites...EkZP21n3mB7jN1AQ8fSlDA-Xx8gw==&attredirects=0
If you want to be uh, "precise," you can measure the outputs of the tweeters, and change the 6 and 10 ohm resistors to make the outputs equal. I don't know offhand if different drivers of the same model vary in sensitivity enough to worry about, but if so, there you are.
Going from 6 to 5.6 or 6.2 would change the tweeter level by about (taking a SWAG) a tenth of a dB, which is pretty much an inaudible change.
- Can I use this resistor in a crossover?
