World's Best DAC's
I really wonder how many DAC's you and SY have had in your system and compared before being able to have the opinion that a soundcard is good enough for hi-fi.
What's an acceptable number before I don't have to hang my head in shame over using and recommending a system with no interconnection issues, vanishingly low distortion and noise, and fantastically flat frequency response?
so you use a soundcard?
If you compare very good dac to your soundcard, it should be obvious enough that your soundcard sounds terrible.
you just need to try good dacs. one will suffice!
In what sense not good?* And which model, they've done at least 6 with the name fireface!
* more air or wider soundstage is not a valid answer to this question.
rme fireface 400.
not even close to a buffalo dac. Details, transient, dynamics, ect. better at everything.
then my sd player from ecdesigns is much better then buffalo. comparing the RME to ecdesigns is very obvious why a soundcard is very compromised design.
the sd player by ecdesign come very close to analog. Its basically at the level of my analog playback,
But SY is using analog playback most of the time, no?
No experience with an RME Fireface. Perhaps you can share your experience doing ears-only testing of something like an M-Audio PCI card versus a well-engineered external DAC.
I dont have a m-audio PCI.
just last week, one of my friend got a cheap HRT music streamer 2. he used to use his onboard PC soundcard. he is blown away by the difference between the cheap external HRT dac and his pc soundcard.
Hi YouKnowYou, How do you find the mosaic vs the TDA1541 you had before
im still waiting for my mosaic 16T 🙂.
I talk to hans satink who replaced his sd player with the new mosaic and he told me:
''Yes, it is far better then the SDplayer. You will hear truly all 16 bits and the noise/distortion level is unmeasureable.''
Well the fireface IS an external DAC. So I think he means ' I tried a multichannel pro recording box and my belief system didn't let me think it was good'. I mean how can 8A/D channels in and 8 D/A out with a (horror) variable frequency clock be any good. 🙂
So, the pack is trying to argue to set a thruth?
Show the numbers please as what these DACs can accomplish is beyond hearing. Please no DAC chip manufacturers happy tables but only what third party or yerself have managed to measure. Screenshots of course is what matters - 10hz to 100khz loopback to whatever mic input you have on yer computer. Software to be decided as I don't have the deeper knowledge needed to be counted into this decision - stated elsewhere.
The rest is about "I bought this - I hope everyone else thinks it was a good deal... Otherwise I bet on the wrong horse."
yes, the pci m audio from SY is much better 😛
so, now moderators do not believe in the audibility of dacs.
again, I wonder how many external dac you have tried SY in your system?
because to be able to claim such, ime, non sense about dac, i sure do hope that you have tried many dacs, for many days, in your system in order to come to a conclusion that your soundcard is has good as anything and claim this as fact.
SY, can you state which dac you have compared? how did you do the test? I'm very interested.
Jon, do you have any passively xo'ed speaker that you could use for comparisons also?
I think the results are not very reliable when using a "bandwidth-limited error detector" to detect the errors, aka. using one band of the speaker. Too many things can skew the results and all the differences cannot be heard.
I have done that also myself in the past when trying out different amplifier in a active setup. All sorts of comparisons are so much more revealing and satisfying with passive xo'ed speakers, imo. They also sound simply better to my ears (compared to MiniDSP Nanodigi with the same DAC). All the electrical interaction between drivers and current drive situations in the passive crossover etc. cannot be replicated with an active setup. If you can make the speaker at least partially passive, I suggest to try it. 🙂
Most revealing set-up (on DAC's differences) are my RAAL 210-10D tweeters so far... It's pretty much day & night when i switch from one to another: and by that i mean i would be confident to bet some bucks in a blind test, which doesnt happen that much 😀
Of course i could try my Voxativ AC-1.6 in fullrange mode, maybe that could help... But i don't have the enclosure to go very low.
This is a very bad way to come to conclusions.
The only thing you need to prove is that a specific piece of equipment is transparent, in the sense that in controlled listening tests, it is impossible to differentiate between in- or exclusion of the device.
