With JLsound XMOS_AK4490 and older AK4396 working perfectly.. I use 64bit rt version..
Try to clear library and rescan everything, maybe helps..
I use 486 version. Library isn't an issue, for sure. Music library loads fine, but audio device doesn't. I'll wait for another release.
Are you sure?!Library isn't an issue, for sure..
Try to clean and rescan everything, and try to reset all setings to the latest firmware defaults..
Are you sure?!
15.09 Works, 15.08 aswell, 15.10 doesn't.
My library is 2TB (rescan takes a lot of time), so, I'll wait for 15.11 version or 15.12.
15.10 works.. but you don't want to read carefuly.. Daphile have few different rescan options, you must use 'clear library and rescan everything'..
How much You preferi the the 4490 over the old 4396 jlsound dac?
Inviato dal mio SM-N910F utilizzando Tapatalk
I see the music library (albums and songs), bus AUDIO DEVICE isn't listed ... But OK, I see that you don't want to listen.
I'll wait until 15.11 or 15.12.
Yesterday beta have native DSD support..
Finaly I can try DSD256..
So the latest JLSound USB board is able to play native DSD256 on Linux without and drivers ?
May i ask what is the settings on the daphile for 256DSD on JLSound? Any DoP ?
http://www.diyaudio.com/forums/digital-source/236028-xmos-dsd-384-khz-32bit-usb-54.html#post4459650How much You preferi the the 4490 over the old 4396 jlsound dac?
You will not be able to use any new sw without 'clear library and rescan everything' option..
I2SoverUSB - I2S over USB Audio
Choose native instead of DoP in Daphile Settings/Audio Device/DSD support..
Ok, I'll rescan everything over night. Hope it'll work.
You can always contact Kipeta if problem still exists..
About new version..
There are pretty significant internal changes in audio decoding/transcoding/resampling area. Please report the problems with the test case details (audio formats, settings, etc...).
The DSD support on media server has also changed a bit and you should run the "Clear library and recan everything" to get it working properly again.
About new version..
Daphile need about 15' for full rescan of my 1TB HDD..Ok, I'll rescan everything over night. Hope it'll work.
Maybe there is some other problem if you need all night for rescan..
What computer do you use? CPU?
The BruteFIR is not as good as before, every time when change the equalizer or gain, I can hear the click noise. If I enable more than one output; there is a very high pitch noise coming out from speakers while scanning after an new folder is added.
About new version..
You were right about "Clear library and recan everything". It Works now ... 😱
How about BruteFIR mode? It doesn't resample anything, right? Does it work OK?
I don't use BruteFir mode, few users report some problems.. I tried new Daphile version only because of DSD Native support, that works very good..
- PC Based
- Daphile - Audiophile Music Server & Player OS
