how to determine if an output transformer has blown?
ok so i have been working on my amp and i did a classic stupid thing and accidentally hooked up a 8ohm speaker to the 4ohm tap but really quickly shut it off like 3-5 seconds after powering it with only 12v 😡:headbash:. what could the damage be or could i have blown my OPT?🙁 is there a way to test it?😕 i feel angry at myself for making this mistake and i have spent alot of money on the transformer.
Aran
I've been lucky so far. I built a SE amp that requires a 6V6 output valve and then inexplicably ordered a 6L6 - but it seemed to work fine. When I did some measurements I found it was producing more output power than expected, and then I realised!
The thing I do repeatedly is solder jack plugs etc. and then realise afterwards that I should have slotted the body of the plug on to the cable first!
haha i can only imagine! sadly i got the output tube fired up and got no signal and then relised the heaters did not power, then i did some fiddling with the OPT and the tube glows, then i wire it to the schematic and now it dosent glow again so i thought maybe the OPT would not allow current to pass into the anode which would have an affect on the cathode and the heaters maybe so that could be the reason 🙁
Aran
Aran
Hooking up an 8 Ohm speaker to a 4 Ohm tap is not such a bad idea.
When the "tube doesn't glow" then your heater supply is not hooked up or working. It has nothing to do with anything else.
Oh my life..
Just disconnect the primary of the output Transformer and measure the resistance across it..
Calm down and check everything you have done carefully make sure you have all the connections correct on the tubes and output transformer.
M. Gregg
i'm getting a reading on the primary of about 300ohms now...
Check if you get a reading on the secondary (good) and also check if you get a reading from primary to secondary bad).
Check continuity of the heater wire/filament.
Check if the heater supply is hooked up to the heater pins.
Check if the heater supply is putting out a voltage.
