Happy Birthday sir mile.
Happy Birthday! Feliz Cumpleaños! Feliz Aniversário! Parabéns!![]()
Mr Mile Happy Birthday and cheers!!![]()
Thank you.
Ok. Here is something to break the OT chain. I have made a layout of Apex Protect circuit as given by him in post no. 5414. I know the layout can be improved a lot, but I would like to know if it will work as intended.
Also whether some values need adjustment for AX-11 as given in post no. 5402 for rail voltage of +/-35V and trafo secondary voltage of 24V ( i will be using the same AC secondary for PSU as well as Protect).
Prasi
Prasi
Prasi
560R/2W must be change to get 24V on ralay coil.
Ok Thanks Mr. Mile,
I have modified the layout to include the PSU caps and also miniaturized the size a bit. Can you confirm if the AC connections and Gnd connections between the PSU board and Protect board are correct?
regards
Prasi
Ok Thanks Mr. Mile,
regards
Prasi
Nice pcb, ac connections are ok.
That's a nice PCB. If you can shorten it to 100mm you will save a lot of money on the cost of having them made. Most board houses have a "prototype" price for 100mm x 100mm that is dirt cheap. Like $25 for 10 boards including shipping. You go 101mm and the price doubles. Just a suggestion.Ok Thanks Mr. Mile,
regards
Prasi
Blessings, Terry
Thanks Terry, Thats a very good suggestion. I will definitely implement it.🙂That's a nice PCB. If you can shorten it to 100mm you will save a lot of money on the cost of having them made. Most board houses have a "prototype" price for 100mm x 100mm that is dirt cheap. Like $25 for 10 boards including shipping. You go 101mm and the price doubles. Just a suggestion.
Blessings, Terry
reg
Prasi
Blessings, Terry
Done🙂. Its now 100mm x 64.75mm.
Prasi
Nice. What program are you drawing this in? Maybe you could share the file so some us could build it. 😀
Hi Terry,
I used eagle. (most people on the forum seem to hate the poor program😀😀!). However pl find the file in the attached folder. Also png images with 600dpi
Happy building!!
Prasi
- 100W Ultimate Fidelity Amplifier
