speaking of mica - it's still easiest to buy T03 ones
I'm routinely using them for T0247 (when I'm short of these) , punching hole and cutting around with scissorrrrrrs
Zen Mod
What a great idea! I have tried using TO3 micas but couldn't figure out a good way to make it work. Would you be able to describe a little more or sketch a simple diagram of what you do?
How do you punch hole? Thanks
I purchased .5 square meter of the Keratherm product and have lots of it left. I have sold some to various members and happy to continue to do so. And yes the hole punch works great.
you can even use screw and nut as primitive hole puncher
Thanks Zen Mod. That's more my style !
Finally finished my digikey order to cover a few amp projects.
It's amazing how the price of resistors seem add up to a lot more than you think it will be.
I think I spent $90 just in trim pots.
Yes, trimpots are really expensive. "Normal" cmf55 are cheaper at mouser.
Ulf
Ulf
Total order was over $500.
Mostly resistors.
What's your choice for resistors for FW amps?
I went for Vishay RN65 (for 1/4W) and CPF (for 3W), with lowest % tolerance and thermal coefficient that were in stock.
I just use Vishay CMF55 25ppm resistors. I have used Vishay Z Foil resistors in the past but when you're building a stack of amps they are way too expensive.What's your choice for resistors for FW amps?
For power resistors I have used 3W Panasonic Metal Oxide Film and Mills wire wound. For high current feedback I use Vishay CPF 3W. I also have 5W Futaba resistors (but not yet used) and in the order I purchased some Vishay BC components metal film resistors instead of Panasonic this time around.
I was really interested in this amp maybe as a headphone amp, but it's out of stock. I'm just curious if this is still an active kit?
Only the 'kit' with the Transformers and PCB packaged together is out of stock.
Here are the constituent parts:
F-6 clone boards (2 PCBs, makes 2 channels; Rev 2.0) - Power Amplifiers - Circuit Boards
You need the JT-123-FLPCH Line Output Transformers | Jensen Transformers
What do you use for the trimpots? I have been using Bourns but they seem very difficult to adjust when the amp is hot.
Nash
I have used 25 turn pots in the past and single turn pots. Single turn is not enough for my liking. I have now purchased 4 turn bourns pots.What do you use for the trimpots? I have been using Bourns but they seem very difficult to adjust when the amp is hot.
Nash
If you select the diode appropriately then everything becomes much easier.
Part of the problem is also due to the temperature coefficient of the devices. Best to set for 0.7A let the heatsinks stabilise in temperature then start fine tuning. It could take 30 minutes for the heatsinks to reach thermal equilibrium.
Don't know if I am too anal about this stuff, but started measuring and selecting all components.
Nice meter! In the distant past I could look at a carbon comp 5 percent tolerance resistor and knew them by sight . The extra band on modern resistors really caused me a problem . If I have time I measure all resistors for a project to make sure I don't get values mixed up.
I start projects also with measuring and selecting parts. Using a Keithley 2000.
- The diyAudio Firstwatt F6
