TS data for 10" Peavey model 121's?
Does anyone have the specs / TS data for the 10" Peavey model 121 (8 ohm)woofers?
(I have posted on the Peavey forum, but no responses. I have searched their support areas, but no joy, and I can't find anything published elsewhere.)
Thankx
Doug
PS I have a pair of 121's and I'd like to make a pair of light duty subs if the drivers are suitable.
If you've got DSP, there's a lot you can do without T/S parameters.
If they were mine, I'd set out aiming for a 60Hz cutoff, build a cabinet that looks somewhere near the right size, add a 3" port tuned for 60Hz, and EQ the rest. Be careful of massive amounts of boost, but you ought to be able to get respectable performance there.
Alternaitely, its easy enough to measure the impedance curve and derive from there.
Chris
121-8
10" Peavey Sheffield TVX 1035-8
If you have a 10-12W sub amp do a 120-150L sealed enclosure. Qtc = 0.85, F3 37 Hz in room.
A reflex is difficult to tune and might sound awkward (boomy) if not done properly (but accepts more power@Xmax ~50W. For the 4 ohm it's ok, but for the 8 ohm it doesn't work but if interested anyway to know: VB = 200.0 L, FB = 30 Hz. This if the specs are correct. I would measure it myself because it was meant maybe only for sealed?!
Oh dear, that's a big cab!
As I have two, could it be worth running isobaric, to halve the cab volume?
Doug
Hi All,
FYI: One possibility:
b🙂
Thankx
Doug
hello! a bit late but i recently found the tsp. http://webcache.googleusercontent.c...s.xls+peavey+96000296+tsp&gbv=1&hl=de&ct=clnk have fun. http://files.diyaudio.com/forums/images/icons/icon10.gif
