Denon PMA-920 recap
Hi Guys,
I'd like to recap an old Denon PMA-920 because the original caps must be over 25 years old. For the PSU caps I'll most likely go for these LINK because of the high ripple current. The original values are 8200uF but I assume 10000uF will be ok?
Could someone have a look at the circuit diagram for me and tell me what the most important caps are? I'd be over the moon if someone could tell me where the decoupling, feedback and coupling caps are.
Page 1
Page 2
Page 3
Page 4
Page 5
Page 6
Not sure if I can get full resolution if I upload the here but I'll try anyway:
No, 304, 312, 314 and 306 can be film. 220 nF and 100 nF. Same for the other channel, obviously. For values above 2.2 uF, film caps are not economical, and for values above 4.7 uF, size is unacceptable. Anything Panasonic or Nichicon will be fine for electrolytics.
In general, is the goal to replace all electrolytic capacitors with either newer electrolytics or film?
I suppose the other parts to replace are those resistors that dissipate a lot of power.
