The smallest size compression driver and horn?
"Is that really a CD?:
Yes, it really is.
Look at the taper on the face plate, and how it continues the taper on the cone. Look at the taper on the phase plug, see how it matches the taper on the face plate. Look at how much of the cone is blocked by the phase plug, consider how much compression is occurring.
The horn is quite shallow, so it can't load very low in frequency, but it is active horn loaded in the top octave.
If you want to hear what the horn faceplate actually does, just remove it (the driver is twist-locked onto the faceplate). I think you will be surprised at how much it contributes to the sound.
Avantgarde uses a custom compression driver for the midrange in the Trio, the compression ratio is on the order of 2:1, and it sounds very open compared to typical 10:1 midrange drivers.
Compression Ratio: 1.84:1
http://www.communitypro.com/files/literature/spec%20sheets/M200A_SPEC.pdf?phpMyAdmin=c9cc5b3953d87385dc22218d669e7aab
The 2360 horn has 30% THD with 5W input at 10Khz (for instance) driven by a 2445, the M200A on the SH494 has less than 4% (in the midrange where it runs), at 7.5W input. It probably has even less distortion on the Trio mid horn.
400 Hz - 4 kHz (±3.2dB), 111 dB/1W/1M SPL (400 Hz - 4 kHz 1/3 octave bands), 7.5W is about 120dB!
The tweeter for the Trio is a high-compression ratio Beyma 1", CLS just wants too much for their VHF100 low compression (4:1) tweeter driver, which has less moving mass than a TAD 2001. This tweeter is so clean it doesnt sound like it has any HF (I had to get out the analyzer to check and see!).
Looks a bit like a BMS driver, but is really quite different, one half of the ring is missing, and it is only clamped on one side.
By the above logic, covering any part of a tweeter that has a bevelled face plate is a compression driver. Most chinese bookshelf and patio speakers therefore also have compression drivers. I don't agree that just because part of a drivers surface is covered by a phase/dispersion aiding device that is at all a compression driver or horn.
The avante garde drivers are just cone drivers on a horn with a throat cross section smaller than the cone. That would make every hornloaded bass driver a compression driver by that logic. In actual fact, the avante garde throat is barely smaller than the cone diameter.
Been trying to scheme a way to get M200 or M200As to work in my car for a decade with no luck. Finding the VHF100 driver at a decent price is pretty hard to do.
That is a serious deal on that Celestion driver. I may have to buy a few for a rainy day.
..this is worth repeating 3 times:
..the compression ratio is on the order of 2:1, and it sounds very open compared to typical 10:1 midrange drivers.
the horn on Partsexpress buyout's Peavey RX14 is/was small - here (Red trace) it is just sitting on top of a tall cabinet and run with just a 3.3uF cap. The other sweeps are how it behaves on Eminence's Beta 10cx with 2nd order highpass.
