Hypex Ncore
Is it better to do the attenuation in the unbalanced domain with a regular stereo poti, or on the balanced side with a balanced poti? (e.g. from Audio Note Audio Note 100K Balance Potentiometer | Hifi Collective )
Two totally separate issues here - one is the balanced vs. unbalanced, and the other the "which side of the connection" question. The pot you link to is a balance pot, not a balanced pot - it is intended to adjust channel balance, it is not intended for a balanced connection.
There is no difference between a "balanced" and "unbalanced" pot - the difference is in how you connect them.
Does it make a difference whether I put the poti close to the source or to the amps (thinking of length of balanced or unbalanced cable [albeit short at less than 1m], interference/intermodulation etc.)?
TNT is right - you want to keep the interconnect driven by a low impedance, so pot comes the receiving (amp) side of the interconnect.
Is a stereo poti like the above Audio Note ok, or are mono potis to be preferred here? (The inconvenience of having to regulate volume separately for either channel, versus sonic superiority...)
There is no "sonic superiority" as such in a mono pot - you can make a ganged dual (stereo) pot just as good as a mono pot, the only possible issues are lack of perfect match between the two pot parts (but as two mono pots have no matching at all, I would say "not perfect" is better than "none at all"), and a possibility of some very minor crosstalk - easily fixed by moving speakers 10 cm further away from each other.
hypex ncore
Many thanks TNT and Julf!
Ouch, mixing up channel balance with balanced connection is pretty embarrassing ;-) I haven't worked with balanced connections before, so am still learning.
So I will put the pots as close to the inputs of the NC400s as I can. Yet with mono amps that ideally would have to result in using mono pots for shortest possible wiring after the pots. I remember having seen designs before that used two motorized mono pots with one remote control to keep the pots quite in sync when changing the volume, but I'd be worried to introduce potential RF and other noise into the sensitive NC400 environment with the pot motors (the control board probably could be shielded appropriately), right...?
Mono amps and volume control is a tricky issue - is there a special reason you want to go for mono amps (like placing them next to/inside the speaker)? If you need volume control, the possible advantages of mono amps is more than undone by the complications involved with arranging the volume control.
I am not sure I would call the NC400 a very sensitive environment. The boards are well laid out and pretty compact.
Synchronizing two motorized mono pots gets pretty complicated.
Not really - it is my (probably pretty paranoid) understanding of 'galvanic isolation' - since the NC400s are connected to the case, not sharing one case but using two separate/independent ones completely eliminates the possibilities of one channel's amp and PS units influencing the other channel's.
Nothing wrong with being paranoid, as long as it is informed paranoia. 🙂
I would not worry about two channels in the same case - I haven't noticed any interference even with 4 nc400's and 2 smps600's sharing a case. Even with two nc400's sharing one SMPS, there is no interference.
Another thing is that the worst thing that could happen even if there was interference would be a slight reduction in channel separation. It wouldn't affect distortion or SNR figures, it would just be the equivalent of moving the speakers a tiny bit closer to each other. Is that worth the fuss with trying to control two separate volume controls?
I also have to point out that even with a dual mono setup, you can never "completely" eliminate any influence - they still share a mains feed. So what amount of influence is acceptable to you?
That is interesting. Would you mind to elaborate why this is the case?
Induced EMF doesn't affect the linearity of an amp* - so no change in distortion. It can cause noise - but in this case it is not random, uncorrelated noise, but noise related to the signal in the other channel - so the effect is that of (very small) crosstalk.
The best way to think about it is "what would I hear from the output of an empty channel when there is a signal on the other channel?".
Go for a DAC with digital level control if thats your only source would be my advice.
hypex ncore
Absolutely, this will arrive in a few months. Yet I have another older DAC which I love, a phono preamp and a SACD player, all without volume controls. Would have preferred to omit a preamp if possible.
Or if that isn't possible, add a volume pot + buffer stage to the DAC output.
Is that really better than a pot directly at the amps' inputs...?
also are these excellent modules and power supply really that sensitive to the least complex part of the build - putting in a chassis and hooking up the cables.
Nothing can be taken for granted as being less critical to the success of the implementation. Often wiring up the connectors and PSU can be more critical with modules as it is quite easy to destroy a products excellent objective performance by putting wires in the wrong place.
This is especially true with amplifiers where you have to deal with both low and high impedances, high and low signal levels and high and low current signals and their associated return paths.
So just when you thought nothing could go wrong hehe.
So what is your recommended solution?
first of two 2ch ucd400 done and playing.
pardon me if ucd amps are out of place in this thread. Please help move to right thread.
