Old PA enquiry
I stumbled upon an old OHM power amp as part of a clear out from a music program, have tried to find info on it, but can't find much out, the model number is PA150D and I'll leave a photo in case someone recognizes it, any info at
all would be appreciated.
I'd guess at 150w into 8ohm. Mono. Avoid running to 4ohm unless it says you can.
Apart from that, those old mixer-amps are solid. I've got a McGregor one that comes out occasionally when I just need a mic and a speaker on a stick.
So far, I've taken some contact cleaner to all the controls and replaced the main bulk capacitors. Subjectively a bit more oomph before clipping, and the controls no longer have that scratchy sound as they're turned.
Chris
