Hello!
The AC Adapter went missing for my Gemini PMX-80 Preamp Mixer.
I found the service manual here: http://diagramas.diagramasde.com/audio/PMX-80.pdf
- The power source is "115V/15V AC 7.5W" *edited
- 7.5W divided by 15V = 500mA or higher (if i'm correct)
- the input jack is pin positive based on the schematic (if i'm correct)
- 2.5mm input jack
** I can't tell if the original AC adapter is linear or switching**
My question is: Will a cheaper, switching 15V AC-DC adapter be compatible, or would it result in hum / noise? I found one here for $9: http://www.amazon.com/gp/product/B00IX6DAK0
I found a "compatible replacement" here for $27 + shipping: http://www.amazon.com/gp/product/B00PQDGMIK
It appears to be a linear supply, based on the size and non-universal voltage input (if i'm correct).
I'd rather not spend 3x the price if a cheaper alternative could work.
Could anyone tell if the original supply is in fact linear or switching?
I realize I could simply "try and see", however I'd rather not be wasteful in cost/postage, any advice would be greatly appreciated, thank you!
- 2.5mm input jack
- The power source is 115VAC - 15VAC 7.5W
That tells you it is an ac output. So a switching or regulated supply is not suitable.
AC transformers are the simplest PSU you can buy, I would imagine you could pick one up for about 10 dollars.
Hello!
This is simply a 115VAC -15VAC transformer, It is not a DC unit like the switcher, DC units will not work.
There is no polarity on the AC input, you could use a suitable AC transformer, like this for example 15VAC Wall Wart and add a suitable plug
Alan
Thank you richie00boy and Spiny for pointing this out. That was actually a typo; I meant to say "115VAC - 15VDC" but perhaps it is in fact AC-AC after all.
I'd like to clarify that, verbatim, the service manual says "115V/15V AC 7.5W" and the rear jack says "AC IN". Is this enough to safely conclude it is AC-AC?
AC wall warts are useful for providing 2 rails and zero volts from 2 wires.
I have used them in USB mixers and active cross over filters.
If it says AC IN, then count on it needing AC. As others have said, it is nothing more than a transformer, nothing special.
And while this is AC, in other applications that need a DC supply, it doesn't matter if it is SMPS or linear, all that matters is the output is smooth DC of the appropriate voltage and sufficient current.
As others have pointed out, the answer is yes.
There is a specific kind of wall wart that I've used repeatedly for gear like this. Its original purpose was providing AC power for alarm systems and it is typically rated at 16-18 volts @ 1 amp or so.
Example:
New 16 5V AC 2 4A Wall Transformer Power Adapter Screw Terminals 16 5VAC 40VA | eBay
It is used exactly as others have pointed out - both the plus and minus DC supplies are internally created from a single pair of wires.
The manufacturer obtains instant UL compliance and puts the hum-radiating transformer well outside the piece of gear.
The specific gear I have used these with were made by Symmetrix and Rane, but this sort of a power system is commonly used by other manufacturers as well.
- Design & Build
- Parts
- Missing AC adapter for preamp mixer - will this work?
