Quad 63/988 bass and tweeter panels
So, to be sure about which panels are dedicated to bass and to high frequencies, I am guessing the bass panels are at the top and bottom and the high freqency panels at the center. Is this so? And is there an actual xover for this? Thanks.
There are two panel types, two of each to make 4 in the 63/988.
The 989 has two additional bass panels top and bottom.
The diaphragms are individual for each panel.
rgds, sreten.
...I am guessing the bass panels are at the top and bottom and the high freqency panels at the center. Is this so? And is there an actual xover for this? Thanks.
The middle two panels contain 6 ring segments that are fed with a full range signal(not just high frequencies) using a lumped transmission line that delays the signal to each successive ring by about 20µS. After the 6th ring, the line is terminated in it characteristic impedance. The areas making up segment 7 are fed thru two 360Kohm resistors which form a first order low pass filter with the segment's capacitance, rolling off frequencies above about 3kHz. The top and bottom panels(and outer portions of the middle two panels) make up segment 8 which are fed thru two additional 360Kohm resistors. This adds another first order LP filter with roll off starting at about 500Hz. So, the top and bottom panels could be described as bass panels with a rather slow roll off coming from the two section R-C passive crossover.
However, at low frequencies all panels are active not just the top and bottom panels.
The middle two panels produce as much bass as the top and bottom "bass panels".
At higher frequencies, only the first 6 segments produce significant output.
Panel areas that make up segment 7 and 8 are labeled on the image sreten linked to.
Also attached is the detailed schematic and a simplified version showing how the segments are driven
