TPA3251d2
TI has released TPA3251d2 'AKITA" higher power analog in class D chip with higher order modulator similar to Hypex NCore but with pre filter feedback. First heard about it at CES 3+ years ago. Can be configured as 1,2,3 or 4 channel with 36 volt supply for output stage.
I'm really curious how this chip sounds. Pretty impressive description:
"TPA3251D2 is a high performance class-D power amplifier that enables true premium sound quality with class-D efficiency. It features an advanced integrated feedback design and proprietary high-speed gate driver error correction (PurePath™ Ultra-HD). This technology allows ultra low distortion across the audio band and superior audio quality."
I hope the chinese manufacturers will take the first steps soon.
Some short calculation for the required heatsink, worst case:
Rds_on (high/low side): 0.1R
Imax: 14A
Tambient: 30°C
Rth_jc(Top): 0.36°C/W
Power dissipation per channel:
Pd_channel = I²R = Imax²*2*Rds_on = 14A²*2*0.1R = 196A*0.2R = 39.2W
Power dissipation total:
Pd_total = 2*Pd_channel = 2*39.2W = 78.4W
Tcase = Tjunction - Rth_jc * Pd_Total = 125°C - 0.36°C/W * 78.4W = 125°C - 28.224°C = 96.776°C
Rth_heatsink = (Tcase - Tambient) / Pd_total = (96.776°C - 30°C) / 78.4W = 0.85°C/W
Rth_heatsink includes thermal conductivity of heatsink grease.
Lets do the calculation again for Irms (sinus power):
Imax: 14A
Tambient: 30°C
Irms = Imax*sqrt(2) = 14A*0.707 = 9.9A
Pd_channel = Irms²R = Irms²*2*Rds_on = 9.9A²*2*0.1R = 98A*0.2R = 19.6W
Pd_total = 2*Pd_channel = 2*19.6W = 39.2W
Tcase = Tjunction - Rth_jc * Pd_Total = 125°C - 0.36°C/W * 39.2W = 125°C - 14.112°C = 110.888°C
Rth_heatsink = (Tcase - Tambient) / Pd_total = (110.888°C - 30°C) / 39.2W = 2.1°C/W
Much better. 😀
As music is normally not pure fixed frequency sine wave the maximum temperature will likely not reached even at full power.
Lastly, for normal use, with an estimated programm factor of 0.5 there will be:
Imax: 14A
Music programm factor (mpf): 0.5
Allowed max junction temperatur: 90% from Tj = 0.9*125°C = 113°C
Tambient: 35°C
Iprog = Irms * mpf = 4.45A
Pd_channel = Iprog²R = Iprog²*2*Rds_on = 4.45A²*2*0.1R = 19.8A*0.2R = 3.96W
Pd_total = 2*Pd_channel = 2*3.96W = 7.92W
Tcase = Tjunction - Rth_jc * Pd_Total = 113°C - 0.36°C/W * 7.92W = 113°C - 2.85°C = 110.15°C
Rth_heatsink = (Tcase - Tambient) / Pd_total = (110.15°C - 35°C) / 7.92W = 9.5°C/W
Please let me know what heatsink solution you choose, I'm still unsure. BGA heatsinks are quite expensive.
Haven't made my mind up yet.
Heatsinks are a mechanical pain in the ***. I might do something like mount the card to an aluminum plate with the TPA on the bottom side - I'd have to "swiss cheese" the plate a bit to allow clearance for component leads, I'll play around with the idea over the next few days.
