Bybee Fraud Protection
I wonder if there's a cryoed version available?
Oooooooo..... now that would be the cat's pajamas. Maybe could turn my Cyndi Lauper CDs into Diana Krall. It could be that smooth.
FWIW, Cryo does work. A good friend of mine had his entire system cryo'd last year. We spent weeks looking for a good cyro treatment lab. He has measurements before and after that show a marked improvement. He is getting trophies for it. Maybe I can get him to share the measurements.
I have a 'signal enhancer' of my own devising that closely matches the descriptions/instructions/effects of the BSE.
On/under cables/equipment the sonic effects are real and would easily pass the DBLT.
As yet I have not performed measurements and do not have theory explanation but the effects as described for the BSE are fact.
Guys, get with the program, this is possible, and easily implemented.
Dan.
OK lets get this in context.
Is the device physically connected to the equipment?
Is it made of individual components ie a working circuit?
is it a piece of a single material?
Does it work by induction?
What effect do you hear?
You should be able to answer this without giving away the design information.
If its easily implemented then it must comply with known physics?
M. Gregg
So what did he Cryo?
Dip the whole amp speakers etc in liquid nitrogen or selective cables /circuit boards etc?
As you can see I'm sceptical but interested. Ie please tell us exactly what was cryo treated and how.
The reason I ask is because I'm interested to what temperature it was reduced and is this temperature critical.
Ie does freezing have an effect? or is it extreme conditions or is the effect progressive?
Ie is it progressive if you Cryo treat the same parts multiple times is there another change each time?
Or is it a one off effect<<does that effect change or go back over time(is it a permanent change)
So now we can have Cryo treated audio parts? ie Takman REX or REY cryo treated etc..Tantalum cryo treated resistors.
To be honest I'm surprised you can't buy cryo treated parts or send resistors etc away in the post to be done.
Drop the parts in a dish and let it come up to room temp..I'm surprised the sudden change in temp doesn't damage the parts.
Deep fat fryer basket and pool of Liquid nitrogen..😀
Put your parts outside in mid winter..in a plastic bag.
I did this with CDs and thought I could hear a difference But it was probably psycho acoustic. There was a craze years ago putting cables in the freezer..LOL
Freeze your wart or alternatively freeze your resistors..LOL Wartner will sell out now😀
Wrap the parts in cotton wool and empty a can of Wartner into the cotton wool
https://www.weldricks.co.uk/product...n=GoogleShop&gclid=CI6HxpOV1cYCFYLJtAodQzcHRg
Spray a circuit board..etc LOL
M. Gregg
LMAO freeze your bybee,
DIY Pipe Freezing Kit | Hackaday
Place component in cotton wool wrap with plastic bag insert the nozzle spray for ever place in the freezer for slow thaw..😀
Just joking because most people would probably loose there fingers. (pipe freeze kit or other cold stuff)
But I might try it for fun!
NB not with a Bybee..
M .Gregg
Ah its made my Sunday morning catching up with this thread....
Now I'm no scientist but shouldn't at least a glimmer of a theory be there before you start experimentation....
And is Carbon C13 that magical, I'm sure a chemist could answer this🙂
OK lets get this in context......
M. Gregg
Ok, I don't want to say too much for now.
Physical proximity.
No electrical connections.
Is it a piece of a single material?
A composite of elements and compounds.
No ferrous materials involved.
This post is an apt description - Final report on the Bybee Internal Speaker Bullets A/B test....
"Here are the results: the best description that I can think of is what I read others to say from conducting similar tests (actually try and heard them), that the main difference is not what is added, but what is missing: a subtle veil that permeated the entire performance from the lowest lows to the highest highs is no longer there. I didn't know it was there to begin with, and all of the sudden, once lifted, everything became more focused and shinier, but not in a glittery way. The sound is more relaxed. Gone are the last vestiges of grain, especially on the strings and wind sections. Everything sounds more "refined" and true. The bass is more controlled and I can hear more of the impact or "initial punch" on the drums. The mid-range is sweeter, and the highs in the crescendo passages even at loud volume, retain their body an composure, instead of being somewhat strident and glittery. Each instrument section is yet more into focus and more defined its placement."
I would further add...
Systems can go to clip and not get 'nasty'.
Systems can be run at sustained high volume and not induce ear fatigue.
The sense of 'loudness' is removed, and replaced by a sense of powerfulness.
This further induces inclination to 'turn it up' to mastering acoustic level and enjoy the recording as intended...ie at the appropriate level to flatten Fletcher Munson subjective eq.
3D depth information is clearly revealed, as is correct/incorrect acoustic polarity.
Low bass emerges from the floor with pleasing tactile vibration of sofa/carpets/flooring....I have also observed windows rattling only when running system treated and also structural failures, ie brick walls cracking/settling, ceiling cornices releasing.
There is plenty more I could add.....live amplified performances, stage instruments, recording, tv/video displays, FM radio transmission, AM radio reception.
Mr Bybee is correct...reduce 1/f and/or vlf noise and systems change for the better.
Note well that JC specifies devices/topologies with very low inherent 1/f noise.
I expect so.
Dan.
Physical proximity.
Dan.
Is this a DIY buildable unit?
What is your intention..ie to market the item or release it used for free DIY but not commercial gain..
The reason I ask is this a possible Bybee replacement<<oups!
Or perhaps the answer to the thread?
NB it doesn't need to be ferrous to be inductive..
M. Gregg
How cold is pipe freeze spray?
M. Gregg
Dunno, but its pretty easy to go below -50C at home. Would that be enough ?
there are more than two 'types' of electrons.
the key here would be geometry.
I can confirm there are two kinds of Electrons
So you guys sussed it to, but you just haven't made the final connection. There are at least 3 different kinds of electron. Red ones, green ones and blue ones. How else could a CRT work with its R,G and B guns unless they fire coloured electrons.
So taking this further, perhaps the Bybee absorbs one or wavelength of electron and as a consequence, the electrons passing through become 'coloured'.
What colour is a Bybee ? Its as valid an explanation as any 😉
What did you use?
I was thinking you could be lazy and wrap cotton wool around parts on a PCB and freeze the living daylights out of them..😀
I don't know how cold you have to go to get an effect..Just because liquid nitrogen is as cold as it is..is it over kill...😕
Years ago it was a standard Audiophool thing to do to put things in the freezer and leave them for a week. Then defrost in the fridge then leave at room temp for a day. I did it with CD's for a laugh and my friend borrowed them liked them (I didn't tell him about the freezer in case he thought I was nuts) so he bought a couple from the local shop but said the recordings were inferior to mine. Perhaps they were..
M. Gregg
I suggest a new sub-forum titled "Fraudio" where the charlatans, kooks, nutters and the terminally gullible/clueless can freely associate on such topics without rational, scientific or moral constraint. Like a Geek Show of old the rest of us would be free to either stay away or to observe them biting the heads off chickens without actually becoming involved in the action. A strict policy of non-intervention, like that observed by modern anthropologists when studying isolated primitives would be enforced. Anyone posting in this sub-forum would have their "diyAudio Member" tag show as pulsing in fluorescent green for six months after posting.
Or we could just stop feeding the trolls...but it is so tempting.
Some of my old stock of Servisol freezer spray. I thought it might hve been R134a but thats a much higher boiling point having just looked it up.
I think the point is to keep it cold for a while..that is the effect of the foam around the pipe with a plastic cover. I would then put it in the freezer.
I know it sounds nuts but I'm sure I read someone doing a test with a complete CD player in a plastic bag in the freezer for a month and doing a comparison test..I can't remember where I saw it, it was years ago..
NB don't do this it will damage your equipment!
M. Gregg
